Ping & MTU 101 Question
After reading several docs on MTU and overhead I'm still a little confused trying to work out the maxium supported MTU over a particular ethernet WAN circuit.  I need to establish the maxium allowed payload from the provider(should be 1600 bytes), and if the circuit currently has enough overhead to deploy services like MPLS VPN, QnQ etc
My understanding is that I will require a minimum MTU of 1522 bytes for MPLS i.e. 1500 bytes + 14(Ethernet) bytes + 8(MPLS) bytes
Currently I can ping across the circuit with a maximum packet size of 1516 bytes.
Router1#ping 192.168.0.2 size 1516 df-bit source Gi0/1
Sending 5, 1516-byte ICMP Echos to 192.168.0.2, timeout is 2 seconds:
Success rate is 100 percent (5/5)
Router1#ping 192.168.0.2 size 1517 df-bit source Gi0/1
Sending 5, 1517-byte ICMP Echos to 192.168.0.2, timeout is 2 seconds:
# Router 1
interface Gi0/1
Description WAN Link to Router B via Provider-ABC Ethernet Circuit
no ip address
mtu 9000
interface Gi0/1.100 point-to-point
encapsulation dot1q 100
ip mtu 1600
ip add 192.168.0.1 255.255.255.252
# Router 2
interface Gi0/1
Description WAN Link to Router A via Provider-ABC Ethernet Circuit
no ip address
mtu 9000
ip mtu 1600
ip add 192.168.0.2 255.255.255.252
I would asume the ping above would include the following overhead -> 4bytes(dot1q) + 14bytes(Ethernet)?
Therefore 1516 + 14 + 4 = 1534 bytes
Therefore if I wanted to enable MPLS (8bytes) would this mean 1516 - 8 = 1508 MTU?  Which *should* be enough to deploy MPLS VPN's using MP-BGP?
914
