Webcast-Catalyst9k
Ping Respond ?????
Hi,,
I have three diffrenet subnent of
X.X.X.X/27
Y.Y.Y.y/27
Z.Z.Z.Z/27
every this is fine i m geting problem only one host per subnet they are not ping each other.
we are using C2600 router btween these subnet and using satic routes for the advertisment of the subnets.....
host 1 of the X netowk not respondind to the ping from Y and Z network where as all other host respond to the ping when we ping it from Y & Z and same case is with host 1 of Y and host 1 Z network.
with in the same subnet all hots respod properly.....
plz suggest
Gold
Re: Ping Respond ?????
Can you check if host1 of the X network has correct IP setting (mask and default gateway)
M.
Yes I have checked it is fine and Ok
as i have given in all other hosts of the subnet ,,,,
Hall of Fame Super Bronze
Please post configs. Not enough information to determine your problem from your post.
If more simly i can explian !!!
I have one Host1 with 3 three differnet IPs
1st
192.168.1.2 255.255.255.224 192.168.1.1
2nd
192.168.2.2 255.255.255.224 192.168.2.1
3rd
192.168.3.2 255.255.255.224 192.168.3.1
1st one is my Core network 192.168.2.0/27
What i have seen when i chked host1 ip
with ipconfig/all
192.168.1.2 255.255.255.224 192.168.3.1
So should I enable/disable LAN card ????
Should I restart my Machine ????
what can I DO ?????
Best Regards
"192.168.1.2 255.255.255.224 192.168.3.1"
That IP configuration is incorrect on the host, the default gateway should be 192.168.1.1 for any host in the 192.168.1.x subnet.
You are only allowed to have one default gateway on a Windows machine. The default gateway will do the routing decisions for you.
229
