Pix 515 VPN and traeroute and tunnel
I have a FTP server called Ftptran sitting behind a PIX "interface general"
a. My network diagram
Traffic from the ftpserver should pass the pix to the VPN then the destination. I'm having problem with the tunnel , the problem is with my local host " Ftptran"
Trouble shoot
Either a ping or traceroute go past the server.
b. attached is the traceroute from the Ftptran.
fig 2.
Attached is my reduced Pix configuration
My ?. how can I configure the tracerout th pass the PIx interface and I need help
1 ACCEPTED SOLUTION
Silver
Re: Pix 515 VPN and traeroute and tunnel
"Traceroute" command (which can be known as tracert on a PC, trace or traceroute on Cisco IOS® Software, or traceroute on UNIX) can be used to troubleshoot connectivity. The traceroute command can operate differently based on the operating system of the source device.
Refer the section "Use the traceroute Command to Get to the PIX Interfaces" present in the following url which provides more information related to the issue:
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a00800e9312.shtml#topic3
1 REPLY
Silver
158
