Community Member
PIX -520 ?????
hi
I am facing a problem with PIX 520 ,
i have connected it with consol but it did not work ... could not get display.
I have study on cisco site that it will boot with flopy drive .. but i have nt its flopy ... m i right ????
wht could i do ???? how can i connect it ???
thanks and ragards
1 REPLY
Bronze
Re: PIX -520 ?????
hi
may be the image is corrpted, so try to put in a new image, download it from cisco.com,download also the botthelper utility for that image, and the rawrite.exe tool all that stuff must be in the same directory in your PC, after that format a floppy and put it in your PC, excute rawrite.exe this will copy the image into your floppy, after that put the floppy into your pix520, and reboot it , the boothelper will be launched, use tftp to copy that image into the flash memory of your pix.
reboot your pix.
do rate if it helps
86
