PIX and 851 reject DHCP
We have a remote site for telemetry and we have been using Wildblue satellite internet , it is a standard DOCSIS modem with ethernet and DHCP.
We have a PIX 501 there and uses DHCP to acquire address, and VPN tunnel back to HQ.
We no longer can aquire ip address from Wildblue, if you connect PC or cheap Linksys router to modem, it will aquire address.
Here is Debug from PIX
DHCP: SDiscover: sending 278 byte length DHCP packet
DHCP: SDiscover 278 bytes
DHCP Broadcast to 255.255.255.255 from 0.0.0.0
DHCP client msg received, fip=70.41.148.1, fport=67
DHCP: Received a BOOTREP pkt Not for us..: xid: 0x28142990
DHCP: Received a BOOTREP pkt Not for us..: xid: 0x13C680dhcpc_discover_pkt: pro
to = 0x11, lp = 0x44
DHCP: Scan: Message type: DHCP Offer
DHCP: Scan: Subnet Address Option: 255.255.252.0
DHCP: Scan: DNS Name Server Option: 12.189.32.61
DHCP: Scan: Domain Name: wildblue.com
DHCP: Scan: NBNS Name Server Option: 127.0.0.1
DHCP: Scan: Router Address Option: 70.41.148.1
DHCP: Scan: Lease Time: 43200
DHCP: Scan: Renewal time: 21600
DHCP: Scan: Rebind time: 37800
DHCP: Scan: Server ID Option: 10.245.40.14 = E28F50A
DHCP: Scan: found option 4: data length = 4 (bytes) data = 0x 0a f5 28 0e
DHCP: Scan: found option 43: data length = 20 (bytes) data = 0x 66 0b 42 30 30
30 33 37 47 30 30 30 32 65 05 56 61 6c 75 65
DHCP: rcvd pkt source: 70.41.148.1, destination: 70.41.150.60
UDP sport: 67, dport: 68, length: 355
DHCP op: 0x2, htype: 0x1, hlen: 6, hops: 0
DHCP server identifier: 10.245.40.14
xid: 0x18B9D, secs: 0, flags: 0x0
client: 0.0.0.0, your: 70.41.150.60
srvr: 10.245.40.11, gw: 70.41.148.1
options block length: 107
We also tried a 851 router, and here is the debug:
.Apr 14 00:48:43.691: DHCP: Received a BOOTREP pkt Not for us..: xid:
0xDAA36F8
.Apr 14 00:48:44.959: DHCP: Received a BOOTREP pkt Not for us..: xid:
0x203618
.Apr 14 00:48:45.955: DHCP: Received a BOOTREP pkt Not for us..: xid:
0xDBF880
.Apr 14 00:48:46.187: DHCP: Received a BOOTREP pkt
.Apr 14 00:48:46.187: DHCP: Scan: Message type: DHCP Offer
.Apr 14 00:48:46.187: DHCP: Scan: Subnet Address Option: 255.255.252.0
.Apr 14 00:48:46.187: DHCP: Scan: DNS Name Server Option: 12.189.32.61
.Apr 14 00:48:46.187: DHCP: Scan: Domain Name: wildblue.com
.Apr 14 00:48:46.187: DHCP Offer Message Offered Address:
70.41.148.207
.Apr 14 00:48:46.187: DHCP: Lease Seconds: 43200 Renewal secs: 21600
Rebi
nd secs: 37800
.Apr 14 00:48:46.191: DHCP: Server ID Option: 10.245.40.14
.Apr 14 00:48:46.191: DHCP: offer received from 10.245.40.14
.Apr 14 00:48:46.191: DHCP: offer received in bad state: Purging punt
.Apr 14 00:48:46.391: DHCP: Received a BOOTREP pkt Not for us..: xid:
0xD0BD81
.Apr 14 00:48:46.451: DHCP: Re
0x2E263580
.Apr 14 00:48:47.583: DHCP: Received a BOOTREP pkt Not for us..: xid:
0xD7D4AF8
.Apr 14 00:48:50.163: DHCP: Received a BOOTREP pkt Not for us..: xid:
0x147D124
Re: PIX and 851 reject DHCP
Does your provider use PPPoE. If so, you will need to setup your PIX/851 to authenticate to their network. Please see the links below.
http://www.cisco.com/en/US/products/sw/secursw/ps2120/products_configuration_guide_chapter09186a00800eb729.html#wp1037306
http://www.cisco.com/en/US/tech/tk175/tk15/technologies_configuration_example09186a0080093fbf.shtml
Hope this helps.
Brandon
No my provider does not use pppoe, it is DHCP
try and power everyting off for about 10 minutes (modem/PIX/router), then power everything on again. The problem is likely with WildBlue, have you had a chance to talk to them already ?
GNT
Yes I have tried doing that already, even for hours, and also tried leaving pix on, and see if it aquires address after being on for a while, and still no go. It does appear the problem is on Wildblue, but don't understand why the PIX is picky.
Trying to talk to someone at wildblue that has a clue seems impossible.
You can use PPPoE and DHCP together. I have a site with a DSL connection where the provider uses PPPoE. My router pulls an address through DHCP. By default, your modem performs the PPPoE negotiation, but this would not work with the 2821 router that I use. I ended up having to put the modem in bridge mode (you should be able to get info on the steps from the modem manufacturer) and let the 2821 perform the PPPoE.
Hope this helps.
Brandon
Hello Jason,
doesn´t WildBlue use MAC address verification ? I don´t think the PIX has support for MAC address cloning, but you could try and configure:
mac-address-table static interface_name mac_address
using the MAC address of the PC or the Linksys router that work and do get an IP address.
I am thinking that WildBlue should at least be able to verify which MAC address is registered with them...but from what you are saying, that appears to be a problem...
GNT
345
