PIX nat to ASA nat question
Drew Browning
How do I convert my old Cisco PIX nat statement to the Cisco ASA 9.1 code?
Original NAT statement:
global (outside) 71 1.1.1.1
nat (inside) 71 access-list ACL-inbound 0 0
access-list ACL-inbound permit ip host 192.168.1.1 any
2 Accepted Solutions
You are having a policy-NAT config with an ACL that has a destination of "any". So you could write that statement also as
nat (inside) 71 192.168.1.1 255.255.255.255
That's a dynamic NAT-translation that can be configured in two ways in the new code:
With Auto/Object-NAT:
object network HOST
  host 192.168.1.1
  nat (inside,outside) dynamic 1.1.1.1
With manual-NAT:
object network HOST
  host 192.168.1.1
object network HOST-NAT
  host 1.1.1.1
nat (inside,outside) source dynamic HOST HOST-NAT
You have to split that as you have two different needs:
  • Normal NAT
That can be configured as the above mentioned manual-NAT where you also can use an object-group instead of an object. The third ACL-line is probably a typo?
object-group network NAT1
  network-object 192.168.1.1
  network-object 192.168.2.0 255.255.255.0
nat (inside,outside) source dynamic NAT1 HOST-NAT
  • Policy NAT
For that you also have to configure manual NAT as you need to specify the destination. Here the destination in not changed:
object network HOST1
  host 192.168.1.2
object network DEST-HOST
  host 169.0.0.1
nat (inside,outside1) source dynamic HOST1 HOST-NAT destination static DEST-HOST DEST-HOST
BTW: This is more a Security-Firewalling topic. You should move it to the right area of the forum.
6 Replies 6
I did looked at that prior to posting this, but it didn't have exactly what i was looking for and i was also looking for a little bit of detail and explanation on how and why it works with the new code.
object network HOST
  host 192.168.1.1
With manual-NAT:
object network HOST
  host 192.168.1.1
  host 1.1.1.1
Perfect!!!
Thank you
What if i were to have this.......
access-list ACL-inbound permit ip host 192.168.1.2 host 169.0.0.1
access-list ACL-inbound permit ip 192.168.1.1 255.255.255.0 any
  • Normal NAT
  • Policy NAT
  host 192.168.1.2
  host 169.0.0.1
