PIX515E DMZ Routing Question
Here's my situation we're a WISP and the PIX515 is our gateway to the internet for our clients. All of our clients are on the DMZ of the pix 172.16.0.1 /16. They receive static private IP's along that range. When someone needs a public IP I do a 1 to 1 translation on the pix and open up what incoming ports they need. What I want to be able to do is simply put the public IP address right on their computer/firewall and not have any ports blocked. Any Suggestions?
Re: PIX515E DMZ Routing Question
you could assign a subnet from your official IP address range to this task and apply it to a DMZ interface. I would recommend a separate interface for this task. This would be configured along what you already do.
Hope this helps
Martin
Gold
not sure if i understand your issue correctly.
the extra bit you are trying to do is to permit all ports for the public ip, and leave the security open as a client's own responsibility.
e.g.
static (dmz,outside) 172.16.x.x netmask 255.255.255.255
access-list inbound permit ip any host
access-group inbound in interface outside
clear xlate local 172.16.x.x
112
