Community Member
%PLATFORM_UCAST-3-ADJ: MAD Lock failed
Hi, I see this error message in my Cisco 3750 switches.
Any one can tell me what's the problem?
Oct 19 10:44:15: %PLATFORM_UCAST-3-ADJ:
MAD Lock failed (IP:10.172.1.1 MAD - rwi:10F ref:0 Ret:2)?
-Traceback= 6B2754 6A10E4 69AC5C 69B488 6F62A0 6F6D28 24EB34 24F26C 24FD10 373930 1ECFFC
Re: %PLATFORM_UCAST-3-ADJ: MAD Lock failed
Hi Kevin,
This message means that the adjacency module for unicast routing encountered an error.
Can you plese post the output of sh version.
Ankur
Community Member
S1#sh ver
IOS (tm) C3750 Software (C3750-I5-M), Version 12.1(19)EA1c, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Tue 03-Feb-04 08:18 by yenanh
Image text-base: 0x00003000, data-base: 0x0091D318
ROM: Bootstrap program is C3750 boot loader
BOOTLDR: C3750 Boot Loader (C3750-HBOOT-M) Version 12.1(14r)EA1a, RELEASE SOFTWARE (fc1)
S1 uptime is 22 weeks, 5 days, 23 hours, 28 minutes
System restarted at 11:38:49 nzst Thu May 12 2005
System image file is "flash:/c3750-i5-mz.121-19.EA1c.bin"
cisco WS-C3750-24TS (PowerPC405) processor (revision F0) with 118776K/12288K bytes of memory.
Processor board ID CAT0847K1GU
Last reset from power-on
Bridging software.
4 Virtual Ethernet/IEEE 802.3 interface(s)
24 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
The password-recovery mechanism is enabled.
512K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address : 00:12:80:BF:2E:00
Motherboard assembly number : 73-7055-08
Power supply part number : 341-0034-01
Motherboard serial number : CAT084719G9
Power supply serial number : PHI083900DY
Model revision number : F0
Motherboard revision number : A0
Model number : WS-C3750-24TS-E
System serial number : CAT0847K1GU
Hardware Board Revision Number : 0x06
Switch Ports Model SW Version SW Image
* 1 26 WS-C3750-24TS 12.1(19)EA1c C3750-I5-M
Configuration register is 0xF
S1#
Community Member
help!!!
Community Member
You are running into the following bug:
CSCed08256 - 12.2S:MAD Lock failed (IP:x.x.x.x MAD - rwi:A ref:0 Ret:2)
This is fixed in 12.2(18)SE and onwards.
1235
