Ple help to verify on comand HSRP
rechard_hk
Dear All,
I need all of you to verify command HSRP that i was configure 2 switch for (Active/Standby).On switch 3560G
1- core-switch 01 (Active)
interface Vlan10
ip address 192.168.3.3 255.255.255.0
ip access-group aclall out
standby 7 ip 192.168.3.2
standby 7 timers 1 3
standby 7 preempt
2-Core-Switch 02(Standby)
interface Vlan10
ip address 192.168.3.4 255.255.255.0
standby 7 priority 200
standby 7 preempt
So the command as above is it correct? if i use those command the Core-switch01 is Active or not ? and the Core-swithc 02 is standby or not?
Best Regards,
Rechard_hk
6 Replies 6
Jon Marshall
Rechard
The higher priority becomes the active router. If you don't specify a priority then the default is 100. So core switch 2 will become the active in your config -
make these changes
core switch 01
int vlan 10
standby 7 priority 110
core switch 02
int vlan 10
no standby 7 priority 200
Jon
Dear Jon,
Thank you for your help!!!
Ok! i understand that you show me..
i would like to ask you some question as below:
1- which number standard priority ?
2- which number standard timer ?
3- could you help verify me again for command that timer,preempt: should i put this command on the both switch(active/standby)
4- normally, when the active down it take a few minute to change to standby.so i don't want to take a few minute, i want... when the active down, the standby will up immediately(not need to wait afew minute).
best Regards,
Rechard
The standby timers set the interval in seconds between the hello message to be exchanged between the active and standby router
in order to find out the if the active router is down. Here you have set the interface timer to be 1 second and it waits for the 3 hello message acknowledgement to declare the interface is down.
You could very well configure the Preempt command on both the active and standby routers as well. Preempt will make the router to be known as the active based on the priority configured.
Change the priority value of core 2 switch to less 100 as the core 1 switch doesnt configured with Priority value so it will take the default value as 100.
Use the following commands to verify if its working properly...
show standby "standby_number"
debug ip standby
jbrenesj
Level 3
Level 3
What is in ACL "aclall"?
You don't want to be filtering the HSRP hello's between the switches
Don't think it matters as acl's applied outbound on a L3 Interface does not affect traffic generated by the router/switch itself.
If the acl's were inbound then yes they could affect traffic.
Jon
