10-14-2006 08:21 AM - edited 03-03-2019 02:21 PM
Please see the attached picture. Basically I have been assigned a /28. I have (2) 2800 routers that each have a connection to the same ISP. I would like to split the /28 and advertise a /29 out one pipe, and a /29 out the other. The problem I am having is that nothing gets advertised unless I just have the network statement 172.16.100.0 mask 255.255.255.240. See below for how I would like it to work..
2800-1
fa0/0 ip add 10.10.10.1/30 (goes to ISP)
fa0/1 ip add 172.16.100.2/28 (goes to ASA)
ip route 172.16.100.0 255.255.255.248 172.16.100.1 10 (ASA) To get in routing table
router bgp 65123
network 172.16.100.0 mask 255.255.255.248
neigh 10.10.10.2 remote 200
neigh 172.16.100.3 remote 65123
2800-2
fa0/0 ip add 20.20.20.1/30 (goes to ISP)
fa0/1 ip add 172.16.100.3/28 (goes to ASA)
ip route 172.16.100.8 255.255.255.248 172.16.100.1 10 (ASA) To get in routing table
router bgp 65123
network 172.16.100.8 mask 255.255.255.248
neigh 20.20.20.2 remote 200
neigh 172.16.100.2 remote 65123
Solved! Go to Solution.
10-14-2006 09:13 AM
Hi Scott,
The reason your are not able to advertise the /29 subnet may be because the route is not in your IGP routing table.
Can you see the /29 routes when you do a sh ip bgp
To make sure the networks fallback you should advertise one /29 subnet from router1 with a higher metric (use ASs prepending) to your ISP and the reverse on router2.
But this may not work as your ISP will be filtering your private AS
If your ISP can accept MEDs then instead of AS prepend advertise MEDs to him with suitable manipulation
2800-1
router bgp 65123
neigh 10.10.10.2 route-map Map1 out
access-list 1 permit 172.16.100.0 0.0.0.7
access-list 2 permit 172.16.100.8 0.0.0.7
route-map Map1 permit 10
match ip address 1
set as-path prepend 65123 65123 65123
route-map Map1 permit 20
match ip address 2
2800-2
router bgp 65123
neigh 20.20.20.2 route-map Map1 out
match ip address 2
match ip address 1
HTH, rate if it does
Narayan
10-14-2006 09:05 AM
Can you give us the output of the":
show ip bgp 172.16.100.0 255.255.255.248
show ip bgp 172.16.100.8 255.255.255.248
show ip bgp neighbor 172.16.100.2 adve
show ip bgp neighbor 20.20.20.2 adve
Vlad
10-14-2006 09:13 AM
Hi Scott,
2800-1
router bgp 65123
match ip address 1
match ip address 2
2800-2
router bgp 65123
match ip address 2
match ip address 1
Narayan
10-14-2006 09:54 AM
You need a matching route in the RIB for the network to be advertised. Remove the existing static route(s) and add the following. Then, issue the command 'clear ip bgp soft * out' for the change to take effect.
2800-1:
ip route 172.16.100.0 255.255.255.248 f0/1
2800-2:
ip route 172.16.100.8 255.255.255.248 f0/1
Sundar
