Webcast-Catalyst9k
please help me: not able to boot 2501 geting error like
hello,
I am having 2501 series router but when i am going to on it i got error mesg. like:
System Bootstrap, Version 4.14(6)[fc3], SOFTWARE
Copyright (c) 1986-1994 by cisco Systems
2500 processor with 8192 Kbytes of main memory
Abort at 0x103AA6A (PC)
Abort at 0x10005BC (PC)
Abort at 0x10005BE (PC)
Abort at 0x10005C0 (PC)
please help me to solve issue
regards
Devang
Re: please help me: not able to boot 2501 geting error like
Hi.
plz chk ur config Reg valu ???
and rest it on 0x2102.
reboot ur router and press Ctr+ break key where u enter in rommod and where
confreg 0x2102
and
reset
hopefullyy it will work
T
hi,
thanks for reply
i tried that but router not allow me to enter in rommod
is there any thing
regards
Devang
hello,
sounds like DRAM problem. to confirm remove the DRAM an reboot.
HTH,
cisand
Hall of Fame Super Gold
on a 2501 I think it is more likely to be flash than DRAM. But reseating both the flash and the DRAM would be good things to do in troubleshooting this problem.
I have experienced problems similar to this which were resolved by reseating flash and DRAM.
Rick
hello Mr Rick,
one more help please...how to reset the both memory?
what is the procedure for that?
regards
Devang
Devang
It has been a long time since I did this on a 2501. My memory is that you open up the case and find the flash and DRAM chips on the main board. Remove the chips and reseat the chips. close the case up and power up (and hope for a successful boot).
Rick
here is a link explaining how to proceed with dram relacement on c2500 series
http://www.cisco.com/univercd/cc/td/doc/product/access/acs_fix/cis2500/2501/2500ug/maint.htm
If your dram ius faulty you can find some on ebay at very good price.
cisand
hello,
thanks a lot for your reply. i will try it out...
thanks again
regards
Devang
151
