Please help Need help with configuring this vlan.
Hi i have attached a packet tracer file here can somebody take alook and vlan the 2 wireless clients on the chicago and bangor network.
Im in desperate need here please and ive been at it for over 1 week, please help.
Purple
Could you explain better what you want to do because both clients on both sites can communicate with clients on the other site.So what is the problem you want to solve.
Alain
Re: Please help Need help with configuring this vlan.
I have created 3 routers in a network Phoenix,Chicago and Bangor.
Each network has a switch, wireless access point and server.
Im trying to setup a vlans for the wireless components only and im struggling.
Since my first post ive setup vlans and assigned them to the ports on the switch but now things will not communicate.
Can somebody please look at my packet tracer file.
I have uploaded my file again as ive progressed alittle further. but im stuck and im about to give up .
Purple
Things were working correctly on my side with the first file you sent, why did you change the adressing?
It is still working this timeso I don't understand the problem?
Alain
I had the default gateways wrong, that is why there was no ping between vlans. I discovred that the default gateway needs to be assigned as fa/0/0.1, fa0/0.2, fa0/0.3 etc. I had to do this on each device but it works fine now.
200
