please help Urgent !!!
Cisco 7206VXR
r1#show int g0/3
GigabitEthernet0/3 is down, line protocol is down
Hardware is MV64460 Internal MAC, address is 0021.a177.bc19 (bia 0021.a177.bc19)
Description: gi0/3--cs2-gi5/3
Internet address is x.x.x.
MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
reliability 253/255, txload 1/255, rxload 1/255
Keepalive set (10 sec)
Full-duplex, 1000Mb/s, link type is autonegotiation, media type is SX
output flow-control is XON, input flow-control is XON
Last input 02:58:01, output 02:58:01, output hang never
Last clearing of "show interface" counters 17w1d
Queueing strategy: fifo
Output queue: 0/40 (size/max)
6507438 packets input, 3948630701 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog, 0 multicast, 0 pause input
6411524 packets output, 2864443126 bytes, 0 underruns
13 output errors, 0 collisions, 12 interface resets
13 lost carrier, 0 no carrier, 0 pause output
cisco WS-C4510R
sw#show int g5/3
GigabitEthernet5/3 is down, line protocol is down (notconnect)
Hardware is Gigabit Ethernet Port, address is 0012.8042.1f3f (bia 0012.8042.1f3f)
Description: gi5/3---gi0/3
Full-duplex, 1000Mb/s, link type is force-up, media type is 1000BaseSX
input flow-control is off, output flow-control is off
Last input 02:48:21, output never, output hang never
Last clearing of "show interface" counters 31w5d
L3 in Switched: ucast: 117755 pkt, 14932307 bytes - mcast: 0 pkt, 0 bytes
L3 out Switched: ucast: 56606 pkt, 11479071 bytes - mcast: 0 pkt, 0 bytes
8320414 packets input, 4144879380 bytes, 0 no buffer
Received 6353047 broadcasts (0 IP multicast)
152540 runts, 0 giants, 0 throttles
the interface g0/3 was on halg duplex I change it to full now the whole link is down ,, please save the night
Hall of Fame Super Gold
Re: please help Urgent !!!
Shut / no shut, or reload.
Hi thanks for the quick response .. I did shut/ no shut and that did not work
none of them worked ,,
Hall of Fame Super Silver
Hello Ocporbust,
being a fiber based link it should be 1000 Mbps full always not configurable.
I don't understand why one side was telling it was half duplex.
I would try to remove all duplex commands but I suspect the gbic is not working well.
Edit:
being a GE port with two possible plugs
int gi0/3
no full duplex
media-type sfp
shut
no shut
Hope to help
Giuseppe
Giuseppe the man in the house ,
We definitely have a bad GLC-SX (SFP)
Thanks again :-)
181
