Please help with this chap failure
raimj
Here is what I am getting with debug.
The connection drops in 1 second
Can you please tell where is the wrong password coming from?
Apr 10 20:11:54: BR0/0:1 CHAP: O CHALLENGE id 24 len 27 from "kwepdx"
*Apr 10 20:11:54: BR0/0:1 CHAP: I CHALLENGE id 83 len 28 from "rt7206a"
*Apr 10 20:11:54: BR0/0:1 CHAP: Using hostname from interface CHAP
*Apr 10 20:11:54: BR0/0:1 CHAP: Using password from interface CHAP
*Apr 10 20:11:54: BR0/0:1 CHAP: O RESPONSE id 83 len 27 from "kwepdx"
*Apr 10 20:11:54: BR0/0:1 CHAP: I FAILURE id 83 len 25 msg is "MD/DES compare fa
iled"
gthermaenius
Hi, you need to check your username and passwords on both routers.
router A
username B password cisco
Router B
username A password cisco
That should do it.
chinkevi_2
the router received incoming failure, so remote router fail the authentication.
Tharak Abraham
Level 3
Level 3
This is a password mismatch for sure
If you notice the I and O which represents the input and output respectively, so either "kwepdx" is senting a wrong password or "rt706a" is configured with the wrong password.
