Please help, youtube and gmail suddenly not working with Cisco 2821
Hello everyone,
I would appreciate any guidance in this scenario. I have an old Cisco 2821, which has not had any edits to the configuration, but the users on Vlan3 (172.16.9.1) are suddenly not able to access youtube and gmail (172.16.8.1 and 172.16.10.1 are unaffected). Could this be a DNS issue or something else? I scrubbed anything that might be a privacy risk, but let me know if I missed anything. This is my first post/request for help.
Thanks so much,
Jonathan
version 12.4
service timestamps debug uptime
service timestamps log uptime
service password-encryption
hostname XXX
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no logging console
enable secret 5 XXX
no aaa new-model
resource policy
clock timezone EST -5
clock summer-time EDT recurring
ip subnet-zero
no ip source-route
ip cef
no ip dhcp use vrf connected
ip dhcp excluded-address 172.16.10.1 172.16.10.10
ip dhcp pool wcpl_wireless
   network 172.16.10.0 255.255.255.0
   domain-name XXX
   dns-server 8.8.8.8 8.8.4.4
   default-router 172.16.10.1
ip flow-cache timeout active 1
no ip bootp server
no ip domain lookup
ip domain name XXX
crypto pki trustpoint TP-self-signed-XXX
 enrollment selfsigned
 subject-name cn=IOS-Self-Signed-Certificate-XXX
 revocation-check none
 rsakeypair TP-self-signed-XXX
crypto pki certificate chain TP-self-signed-XXX
 certificate self-signed 01
XXX
username XXX privilege 15 secret 5 XXX
crypto isakmp policy 10
 encr 3des
 hash md5
 authentication pre-share
 lifetime 1000
crypto isakmp key XXX address XXX
crypto ipsec transform-set wild1 esp-3des esp-md5-hmac
crypto map WILD1 10 ipsec-isakmp
 set peer XXX
 set transform-set wild1
 match address 100
interface GigabitEthernet0/0
 description Public Computers - Main                                    $FW_OUTSIDE$
 ip address XXX 255.255.255.248
 ip flow ingress
 ip flow egress
 ip nat outside
 no ip virtual-reassembly
 ip route-cache flow
 duplex auto
 speed auto
 crypto map WILD1
interface GigabitEthernet0/1
 ip nat outside
 ip route-cache flow
 duplex auto
 speed auto
interface FastEthernet0/0/0
interface FastEthernet0/0/1
 switchport access vlan 2
interface FastEthernet0/0/2
 switchport access vlan 3
interface FastEthernet0/0/3
 switchport access vlan 4
interface Vlan1
 description $FW_INSIDE$
 ip address 172.16.7.1 255.255.255.0
 ip nat inside
interface Vlan2
 description Public$FW_INSIDE$
 ip address 172.16.8.1 255.255.255.0
 ip nat inside
 ip route-cache flow
 ip policy route-map PUBLIC
 vlan-id dot1q 2
  description Public
  exit-vlan-config
interface Vlan3
 ip address 172.16.9.1 255.255.255.0
 ip nat inside
 ip policy route-map STAFF
interface Vlan4
 description wcpl_wireless
 ip address 172.16.10.1 255.255.255.0
 ip access-group 150 in
 ip nat inside
interface Group-Async0
 physical-layer async
 no ip address
 no group-range
ip classless
ip route 0.0.0.0 0.0.0.0 XXX
ip flow-export source GigabitEthernet0/0
ip flow-export version 5 peer-as
ip flow-export destination XXX 4739
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat translation tcp-timeout 1800
ip nat pool sPublic XXX netmask 255.255.255.248
ip nat pool sWireless XXX netmask 255.255.255.248
ip nat inside source list 120 pool sPublic overload
ip nat inside source list 122 pool sWireless overload
ip nat inside source list 123 interface GigabitEthernet0/1 overload
access-list 23 permit any
access-list 100 permit ip 172.16.9.0 0.0.0.255 172.16.2.0 0.0.0.255
access-list 100 permit ip 172.16.9.0 0.0.0.255 172.16.4.0 0.0.0.255
access-list 100 permit ip 172.16.8.0 0.0.0.255 172.16.2.0 0.0.0.255
access-list 100 permit ip 172.16.8.0 0.0.0.255 172.16.4.0 0.0.0.255
access-list 100 permit ip 172.16.8.0 0.0.0.255 172.16.254.0 0.0.0.255
access-list 100 permit ip 172.16.9.0 0.0.0.255 172.16.254.0 0.0.0.255
access-list 120 deny   ip 172.16.8.0 0.0.0.255 10.0.4.0 0.0.0.255
access-list 120 deny   ip 172.16.8.0 0.0.0.255 172.16.0.0 0.0.255.255
access-list 120 permit ip 172.16.8.0 0.0.0.255 any
access-list 122 permit ip 172.16.10.0 0.0.0.255 any
access-list 123 permit ip 172.16.9.0 0.0.0.255 any
access-list 140 permit ip 172.16.9.0 0.0.0.255 any
access-list 145 permit ip 0.0.0.0 255.255.255.0 any
access-list 150 permit ip 172.16.10.0 0.0.0.255 host 172.16.8.91
access-list 150 permit ip 172.16.10.0 0.0.0.255 host 172.16.8.95
access-list 150 permit tcp 172.16.10.0 0.0.0.255 host 172.16.9.4 eq 8080
access-list 150 permit tcp 172.16.10.0 0.0.0.255 host 172.16.8.3 eq 8080
access-list 150 deny   ip 172.16.10.0 0.0.0.255 172.16.8.0 0.0.0.255
access-list 150 deny   ip 172.16.10.0 0.0.0.255 172.16.9.0 0.0.0.255
access-list 150 permit ip any any
access-list 155 remark Websense java-list ACL
no cdp run
route-map PUBLIC permit 10
 match ip address 145
 set default interface GigabitEthernet0/0
route-map STAFF permit 10
 match ip address 140
 set ip default next-hop XXX
control-plane
banner login ^C ^C
banner motd ^C Only Authorized Users ^C
line con 0
 exec-timeout 30 0
 login local
line aux 0
line vty 0 4
 privilege level 15
 password 7 XXX
 login
 transport input telnet ssh
line vty 5 15
 access-class 23 in
 privilege level 15
 login local
scheduler allocate 20000 1000
ntp clock-period 17180208
ntp update-calendar
ntp server 129.6.15.29 source GigabitEthernet0/0
end
42
