Pls help me to interpret the ff. router config
interface Serial0/1
description *** 512k to SFS8131gsp02 (back-to-back) ***
bandwidth 256 <<-- pls explain
ip address 10.0.0.5 255.255.255.252
ip access-group ACL-SFS8131GSP01-06 in
ip nat inside
clockrate 512000 <<< - pls explain
thanks!
1 REPLY
Re: Pls help me to interpret the ff. router config
Check this link http://www.cisco.com/univercd/cc/td/doc/product/software/ios113ed/cs/csprtd/csprtd1/cssyncs.htm
The "bandwidth" is useful to Dynamic Routing Protocol. For example, in OSPF it use in metric calculation. If you don't use Dynamic Routing Protocol, I don't see the use of "bandwidth" command. Check this link regarding "bandwidth" command in serial interface http://articles.techrepublic.com.com/5100-1035_11-6093972.html
To configure serial port in DCE mode, use "clock rate bps" - bps is your line speed. Take note that the higher speed may not work if your cable is too long. To allow higher speed, use only EIA/TIA-449 or V.35
Dandy
94
