05-12-2006 01:44 AM - edited 03-03-2019 12:40 PM
Rourt-A
ip route 0.0.0.0 0.0.0.0 E0
ip route 192.168.11.32 S0
ip route 192.168.11.64 S1
ip route 192.168.11.32 S1 10
ip route 192.168.11.64 S0 10
Router-B
ip route 0.0.0.0 0.0.0.0 S0
ip route 192.168.11.0 Serial0
ip route 192.168.64.0 Serial1
ip route 192.168.11.0 Serial1 10
ip route 192.168.64.0 Serial0 10
Router-c
ip route 192.168.11.0 S0
ip route 192.168.11.0 S1 10
ip route 192.168.11.32 S0 10
Its is full looped routing that why i used distances
when I down interface from Router-A To Router-B it is accessible Via Router-C
But when i down other interface from Router-A to Router-C it is not accessible Via Router-B
(other interfces is up but not working)
plz chck the routing and suggest ?????? any solutions
I think every thing is ok.. but i dont know where is problem ?????
05-12-2006 02:48 AM
Do post out a topological diagram on how your routers are connected and also the ip addressing scheme you have assigned on different interfaces..
That will give a fair info on your setup and the requirement you have.
Also a possible routing protocol too can well fit onto your setup avoiding the hassels involved in defining the static routes everywhere..
regds
05-12-2006 03:05 AM
i have given the interface name intead of any next hop ip ,
thanks
05-12-2006 03:23 AM
Hi Afzaal
do revert back on the connectivity details how Router A , Router B and Router are connected..
regds
05-12-2006 03:41 AM
They are connected via E1
A is connected to B & C
B is connected to A & C
C is connected to A & B
i am tring to send yo the diagrams i f avialbe.
thanks for the replying me.
05-12-2006 03:59 AM
Hi Afzaal
As i hve clearly mentioned in my first post do post the necessary details since the static route or the limited info provided by you in your posts takes nowhere..
regds
05-14-2006 07:07 PM
Afzaalq007,
I'm making some rather large assumptions because you haven't provided the detail.
I think you've made a mistake in Router B It's addressing doesn't follow what you have in A and C. It looks like you are using 192.168.11.0/27 in RTR A
192.168.11.0/27 in RTR B and 192.168.11.64/27 in RTR C
My guess at why it works when you take A-B away is that the whole 192.168.11.0/24 is routed via RTR C anyway and RTR-C has the /27 routes that you are looking for anyway.
When the link between A-C goes away C trys to use B as per weighted route, RTR-B for it's part sends the packet onto RTR-A. RTR-A deals with it appropriately. It's the return path thats faulty. RTR-A dutifully sends the packet to RTR-B, RTR-B however only has two routes to 192.168.11.0/24 to RTR-A and 192.168.11.32/27 connected.
As I stated this is speculation as you haven't provided people very much to go on. If any of the above is correct the problem may be solved with a simple command at RTR-B such as
Ip route 192.168.11.64 255.255.255.224 s1
hope this helps
Tony Henry
05-15-2006 01:48 AM
05-15-2006 02:54 AM
Can you apply this and check ?
Router A:
ip route 192.168.11.32 255.255.255.224 S0/0:0
ip route 192.168.11.32 255.255.255.224 S0/1:1 10
ip route 192.168.11.64 255.255.255.224 S0/1:1
ip route 192.168.11.64 255.255.255.224 S0/0:0 10
Router B :
ip route 192.168.11.0 255.255.255.224 S0/0:0
ip route 192.168.11.0 255.255.255.224 S0/1:1 10
Router C:
ip route 192.168.11.32 255.255.255.224 S0/0:0 10
regds
05-15-2006 06:40 AM
I have same configuration just like you have pasted above, still probelem is same.
i have mention earlier.
thanks for the Annwer.
05-15-2006 02:02 PM
Afzaalq007,
Sorry I can't read the file my version of Visio isn't new enough. Spremkumars suggested config should work.
Can you post the output of a show ip route command from router B?
Can router B's ethernet interface 192.168.11.32/27 reach router C's ethernet interface 192.168.11.64/27 ?
What path does it take to do this? extended pings and trace commands required to do this..
What about during a failure of A-C WAN link?
A quick design question while I'm going. Is there a reason not to use a routing protocol?
Tony
