Community Member
Plz Help in configuring CORE Switch
Hi to All
I am configuring a 4510R chasis core layer switch through cisco configurator. I want to ask u people to help me regarding this selection. So please answer these questions
1. Can i use a single supervisor engine instead of the two. actually cost is the prob here
2. i hav selected WS-X4448-GB-SFP" Catalyst 4500 48-Port 1000Base-X (SFPs Optional) , Do i need to select any thing else for this SFP module.
Actually i need 6 modules supported chasis.
Thanks in advance.
Syed Umair Ali
1 REPLY
Community Member
Re: Plz Help in configuring CORE Switch
hi syed
you can work with one supervisor engine, its not a problem.if you dont need redundancy its not an issue.
syed "ws-x4448-GB-SFP" is a module but according to your requirement you have to choose the connector's.
Regds
Binoy.
107
