Community Member
PoE or Power Injector - AIR1240
Looking to use an AIR1240 on a 3750G-48-PoE.  Is it better to use the PoE from the switch or Power Injector for the AIR1240?  Any advantages or disadvantages to either?
Thanks.
Re: PoE or Power Injector - AIR1240
I've used both w/o any problems. I do like PoE from the switch better though. I can look at the power on the port and add/remove/limit that power. Pretty easy to reboot the AP that way.
Hope it helps.
Hall of Fame Super Gold
My preference is always PoE, however, you have a 48-port PoE switch.  So, do you have alot of clients which require PoE?  If you do, then INJ is my next option.
353
