Community Member
PoE
i have 3750 switch .can anybody tell me how to check whether it supports POE or not.
MOdel No:: WS-C3750G-48TS-S
1 ACCEPTED SOLUTION
Hall of Fame Super Bronze
Re: PoE
show power-inline
http://www.cisco.com/univercd/cc/td/doc/product/lan/cat3750/12240se/cr/cli2.htm#wp8729716
If you have a PoE switch, it will list all the ports with the allocated power. If you don't have a PoE switch, the command will return with no output.
Re: PoE
Community Member
Re: PoE
Thanks for your reply.
Is there any command for the same or we have to rely on the data sheets only.
Re: PoE
show power-inline
Re: PoE
In addition to Edisons post, the POE switch models are marked with letter P (for POE)
for eg. WS-C3750G-48PS-S
Narayan
236
