06-30-2006 06:05 AM - edited 03-03-2019 01:11 PM
i am having a problem with a point to point ethernet handoff. i can't even ping the other router.
i was looking for some help
internal network 192.168.1.0 255.255.255.0
router 192.168.1.2
network
router 192.168.2.2
internet network 192.168.2.0 255.255.255.0
here is my config on my 2.2 router
!INTERFACE AND SUB-INTERFACE
interface FastEthernet1
ip address 172.16.2.2 255.255.255.0
no shutdown
interface FastEthernet2
ip address 192.168.2.2 255.255.255.0
no shutdown
!IP
ip route 0.0.0.0 0.0.0.0 172.16.2.2
ip route 192.168.1.0 255.255.255.0 172.16.2.2
ip route 192.168.1.2 255.255.255.255 172.16.2.2
!RIP
router rip
network 192.168.2.0
network 172.16.0.0
here is my config on my 1.2 router
ip address 172.16.1.2 255.255.255.0
no shutdown
ip address 192.168.1.2 255.255.255.0
no shutdown
!IP
ip route 192.168.2.0 255.255.255.0 FastEthernet1
ip route 0.0.0.0 0.0.0.0 172.16.1.2
!RIP
router rip
network 172.16.0.0
network 192.168.1.0
06-30-2006 06:22 AM
Darren
There are several parts of the configs that you posted that do not make sense or are problematic. First you describe this as an Ethernet handoff, but it is not clear whether the routers are connected via FastEthernet 1 or by FastEthernet 2 or by both. But none of these interfaces share a common network. This would explain why you can not ping between routers. If two devices are connected then the interfaces on which they are connected should be in the same subnet (and same network).
Also the static routes that you post on the first router will not work:
They point at an address that is on a local inteface (FastEthernet 1) but the static route should specify a next hop on another router. You have similar issues with the second static route on the other router.
Rick
06-30-2006 06:49 AM
these are connected via ethernet 1
06-30-2006 08:10 AM
Don't even know where to start on this there are so many issues.
First the ethernet segments must be on the same subnet to work correctly.
Second you should not route to the interface or to the ip address on the interface. You need to route to a destination that outside the router.
What is very scary is that this might partially work. When you route to your own ip or interface the routers ARP all the traffic. Since cisco runs proxy ARP by default the other router may actually respond if it has a route to the network.
You may want to restart with what you currently have and where you want to get and maybe someone can give you a better design.
06-30-2006 08:28 AM
Hi, not even sure how that static to an ip address on that router took. Usually the router will give you an error saying it is this router.
06-30-2006 09:10 AM
You are right it does give you a error if you attempt to put it in after you define the interface. If you do it before you get this situation.
As soon as you reload the router it will remove the routes and give you the error message if you saved the configuration like this.
If you do a debug when its misconfigured this way it will act like it is sending the packets out the interface but I have never verfied if it really does.
