Community Member
Point-to-Point Frame Relay OSPF question....please help. :-)
I'm having some difficulty setting up the last part of my point-to-point frame-relay network.  I've been obsessing about voice so much the last several months that I have probably forgotten the basics of frame-relay over an OSPF point-to-point network.  I have successfully setup OSPF connectivity between HQ-RTR and BR2-RTR, but BR1-RTR is not coming up online within the OSPF topology.  My links are all in up/up status (including on BR1-RTR), but I'm just not sure what I've done wrong since the configurations pretty much match across the board.  BR2's serial interface and router OSPF config should match since HQ-RTR is a the hub in this hub and spoke OSPF topology, but I'm out of ideas.  Can anyone see what I've done wrong?  Again, OSPF is fully connected and neighbor'd up between BR2 and HQ.  I've taken the liberty of pasting the config of the frame relay switch I'm using as my IP-WAN/PSTN as well.
This network is for my CCIE-Voice/Collaboration lab.  But all help would be very much appreciated.  Please excuse my ignorance in this supposedly rather simple network setup.  Keep in mind, I have IPBASE running as the IOS for BR1, but my short research has shown that this shouldn't affect OSPF routing in this network.
Eric
HQ-RTR#show run
Building configuration...
Current configuration : 6669 bytes
version 12.4
hostname HQ-RTR
boot-start-marker
boot system flash c2800nm-adventerprisek9-mz.124-22.YB8.bin
boot-end-marker
logging message-counter syslog
logging buffered 512000 informational
enable secret 5 $1$9FSi$K96RZb3sIlZuEFdsc1URD0
no aaa new-model
no network-clock-participate wic 2
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.11.1 192.168.11.10
ip dhcp excluded-address 192.168.12.1 192.168.12.10
ip dhcp excluded-address 192.168.13.1 192.168.13.10
ip dhcp excluded-address 192.168.14.1 192.168.14.10
ip dhcp excluded-address 192.168.16.1 192.168.16.10
ip dhcp excluded-address 192.168.17.1 192.168.17.10
ip dhcp pool HQ-BR1-Pool
   import all
   network 192.168.11.0 255.255.255.0
   option 150 ip 10.10.210.10
   default-router 192.168.11.1
   domain-name proctorlabs.com
   dns-server 8.8.4.4 8.8.8.8
   lease 8
ip dhcp pool BR2-Pool
   import all
   network 192.168.12.0 255.255.255.0
   option 150 ip 10.10.202.1
   default-router 192.168.12.1
   lease 8
ip dhcp pool PSTN-Pool
   import all
   network 192.168.13.0 255.255.255.0
   option 150 ip 10.10.100.2
   default-router 192.168.13.1
   lease 8
ip dhcp pool Laptop-Pool
   import all
   network 192.168.14.0 255.255.255.0
   default-router 192.168.14.1
   lease 8
ip dhcp pool WIRELESS-HOME
   import all
   network 192.168.16.0 255.255.255.0
   default-router 192.168.16.1
   dns-server 8.8.8.8 4.2.2.2
   lease 8
no ip domain lookup
ip domain name proctorlabs.com
ip inspect name CBAC-FW tcp timeout 3600
ip inspect name CBAC-FW udp timeout 3600
ip inspect name CBAC-FW http java-list 1 timeout 3600
ip inspect name CBAC-FW https timeout 3600
ip inspect name CBAC-FW icmp
ip inspect name CBAC-FW ddns-v3
ip inspect name CBAC-FW smtp
ip inspect name CBAC-FW pop3
ip inspect name CBAC-FW pop3s
ip inspect name CBAC-FW imap
ip inspect name CBAC-FW ftps
ip inspect name CBAC-FW ntp
ip inspect name CBAC-FW ftp timeout 3600
no ipv6 cef
voice-card 0
archive
log config
  hidekeys
crypto isakmp policy 10
encr 3des
authentication pre-share
group 2
crypto ipsec client ezvpn Voice-vRack
connect manual
group proctorgroup key proctorlabs_rental
mode network-plus
peer 74.126.20.247
xauth userid mode interactive
controller T1 0/2/0
controller T1 0/2/1
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface GigabitEthernet0/0
description (Outside Public Interface)
ip address dhcp
ip access-group FW-IN in
no ip unreachables
ip mtu 1300
ip nat outside
ip inspect CBAC-FW out
ip virtual-reassembly
duplex auto
speed auto
no cdp enable
interface GigabitEthernet0/1
no ip address
duplex auto
speed auto
interface GigabitEthernet0/1.11
description (Inside Private Interface)
encapsulation dot1Q 11
ip address 192.168.11.1 255.255.255.0
ip nat inside
crypto ipsec client ezvpn Voice-vRack inside
interface GigabitEthernet0/1.12
encapsulation dot1Q 12
ip address 192.168.12.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.13
encapsulation dot1Q 13
ip address 192.168.13.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.14
encapsulation dot1Q 14
ip address 192.168.14.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.15
description LAB-SERVERS
encapsulation dot1Q 15
ip address 192.168.15.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.16
description WIRELESS-HOME
encapsulation dot1Q 16
ip address 192.168.16.1 255.255.255.0
ip nat inside
interface GigabitEthernet0/1.17
description LAB-HQ-PHONES
encapsulation dot1Q 17
ip address 192.168.17.1 255.255.255.0
ip helper-address 192.168.15.11
ip nat inside
interface Serial0/3/0
no ip address
shutdown
clock rate 2000000
interface Serial0/3/1
description HQ-RTR_IP-WAN
no ip address
encapsulation frame-relay IETF
clock rate 2000000
frame-relay lmi-type ansi
interface Serial0/3/1.1 point-to-point
ip address 10.1.1.1 255.255.255.128
ip ospf mtu-ignore
snmp trap link-status
frame-relay interface-dlci 103
interface Serial0/3/1.2 point-to-point
ip address 10.1.1.129 255.255.255.128
ip ospf mtu-ignore
frame-relay interface-dlci 102
interface Virtual-Template1 type tunnel
ip unnumbered Loopback0
shutdown
tunnel mode ipsec ipv4
router ospf 1
log-adjacency-changes
network 1.1.1.1 0.0.0.0 area 0
network 10.1.1.0 0.0.0.255 area 0
network 192.168.0.0 0.0.255.255 area 0
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 dhcp
no ip http server
no ip http secure-server
ip nat inside source list 101 interface GigabitEthernet0/0 overload
ip access-list extended FW-IN
permit udp any any eq bootpc
deny   ip 10.0.0.0 0.255.255.255 any log
deny   ip 172.16.0.0 0.15.255.255 any log
deny   ip 192.168.0.0 0.0.255.255 any log
deny   ip 224.0.0.0 15.255.255.255 any log
deny   ip host 0.0.0.0 any log
deny   ip host 255.255.255.255 any log
deny   ip 169.254.0.0 0.0.255.255 any log
deny   ip 127.0.0.0 0.255.255.255 any log
permit esp host 74.126.20.247 any
permit tcp any any eq telnet
permit esp host 209.124.41.247 any
permit udp host 74.126.20.247 any eq isakmp
permit udp host 209.124.41.247 any eq isakmp
permit udp host 74.126.20.247 any eq non500-isakmp
access-list 101 deny   ip 192.168.0.0 0.0.255.255 10.10.0.0 0.0.255.255
access-list 101 permit ip 192.168.0.0 0.0.255.255 any
control-plane
ccm-manager fax protocol cisco
mgcp fax t38 ecm
line con 0
line aux 0
line vty 0 4
exec-timeout 30 0
privilege level 15
password cisco
logging synchronous
login
transport input telnet ssh
line vty 5 15
exec-timeout 30 0
privilege level 15
password cisco
logging synchronous
login
scheduler allocate 20000 1000
end
HQ-RTR#
BR2_RTR#sh run
Current configuration : 3643 bytes
! Last configuration change at 04:09:53 UTC Tue Dec 10 2013
version 15.1
hostname BR2_RTR
boot-start-marker
boot-end-marker
! card type command needed for slot/vwic-slot 0/0
enable secret 5 $1$kYuC$TYARPnIw8mjqiVM3CqM15.
no aaa new-model
dot11 syslog
ip source-route
ip cef
ip dhcp excluded-address 192.168.50.1 192.168.50.10
ip dhcp excluded-address 192.168.40.1 192.168.40.49
ip dhcp excluded-address 192.168.40.70 192.168.40.254
ip dhcp pool BR2-PHONES
network 192.168.40.0 255.255.255.0
default-router 192.168.40.1
option 150 ip 192.168.40.1
no ip domain lookup
no ipv6 cef
voice-card 0
license udi pid CISCO2811 sn FTX1328A0D3
redundancy
interface Loopback0
ip address 3.3.3.3 255.255.255.255
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface Service-Engine0/0
no ip address
shutdown
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface Serial0/1/0
no ip address
shutdown
clock rate 2000000
interface Serial0/1/1
description BR2-RTR_IP-WAN
no ip address
no fair-queue
interface Serial0/1/1.1 point-to-point
ip address 10.1.1.2 255.255.255.128
frame-relay interface-dlci 301
interface FastEthernet1/0
description BR2-PHONE1
switchport mode trunk
switchport voice vlan 40
no ip address
spanning-tree portfast
interface FastEthernet1/1
description BR2-PHONE2
no ip address
interface FastEthernet1/2
no ip address
interface FastEthernet1/3
no ip address
interface FastEthernet1/4
no ip address
interface FastEthernet1/5
no ip address
interface FastEthernet1/6
no ip address
interface FastEthernet1/7
no ip address
interface FastEthernet1/8
no ip address
interface FastEthernet1/9
no ip address
interface FastEthernet1/10
no ip address
interface FastEthernet1/11
no ip address
interface FastEthernet1/12
no ip address
interface FastEthernet1/13
no ip address
interface FastEthernet1/14
no ip address
interface FastEthernet1/15
no ip address
interface GigabitEthernet1/0
no ip address
interface Vlan1
no ip address
interface Vlan40
description BR2-PHONES
ip address 192.168.40.1 255.255.255.0
interface Vlan50
description BR2-DATA
ip address 192.168.50.1 255.255.255.0
router ospf 1
network 3.3.3.3 0.0.0.0 area 0
network 192.168.40.0 0.0.0.255 area 0
network 192.168.50.0 0.0.0.255 area 0
no ip http server
control-plane
mgcp profile default
telephony-service
max-ephones 4
max-dn 16
ip source-address 3.3.3.3 port 2000
network-locale ES
time-zone 23
max-conferences 8 gain -6
transfer-system full-consult
create cnf-files version-stamp Jan 01 2002 00:00:00
banner motd ^CBR2 ROUTER CUCME/CUE^C
line con 0
password cisco
logging synchronous
login
line aux 0
line 194
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line vty 0 4
password cisco
login
transport input all
line vty 5 15
password cisco
login
transport input all
ntp server 192.168.15.11
end
BR2_RTR#
PSTN_IP-WAN_RTR#sh run
Current configuration : 3873 bytes
! Last configuration change at 03:31:01 UTC Tue Dec 10 2013
version 15.1
hostname PSTN_IP-WAN_RTR
boot-start-marker
boot-end-marker
card type t1 0 0
enable secret 5 $1$4Dcc$8EzTSAQ0pvm1835G7xoej1
no aaa new-model
no network-clock-participate wic 0
dot11 syslog
ip source-route
ip dhcp excluded-address 192.168.100.1 192.168.100.10
ip dhcp pool PSTN-PHONE
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
option 150 ip 192.168.100.1
ip cef
no ip domain lookup
no ipv6 cef
frame-relay switching
isdn switch-type primary-ni
voice-card 0
license udi pid CISCO2801 sn FTX1016Y07Z
controller T1 0/0/0
cablelength long 0db
controller T1 0/0/1
controller T1 0/2/0
pri-group timeslots 1-3,24
controller T1 0/2/1
no ip address
duplex auto
speed auto
interface FastEthernet0/0.13
description PSTN-PHONE_LAN
ip address 192.168.100.1 255.255.255.0
description MGMT-CONNECTION-via-WIFI
ip address 192.168.1.10 255.255.255.0
duplex auto
speed auto
description FR_to_HQ-RTR
no ip address
no fair-queue
frame-relay intf-type dce
frame-relay route 102 interface Serial0/3/0 201
frame-relay route 103 interface Serial0/1/1 301
description FR_to_BR2-RTR
no ip address
clock rate 64000
frame-relay route 301 interface Serial0/1/0 103
interface Serial0/2/0:23
no ip address
encapsulation hdlc
isdn incoming-voice voice
no cdp enable
interface Serial0/2/1:23
no ip address
encapsulation hdlc
no cdp enable
no ip address
shutdown
clock rate 64000
description FR_to_BR1-RTR
no ip address
frame-relay route 201 interface Serial0/1/0 102
no ip http server
disable-eadi
tftp-server flash:P0030801SR02.bin
tftp-server flash:P0030801SR02.loads
tftp-server flash:P0030801SR02.sb2
tftp-server flash:P0030801SR02.sbn
tftp-server P0030801SR02.txt
control-plane
voice-port 0/2/0:23
voice-port 0/2/1:23
telephony-service
max-ephones 2
max-dn 10
ip source-address 192.168.100.1 port 2000
load 7960-7940 P00303020214
keepalive 10
max-conferences 4 gain -6
ephone-dn  1
number 8087812321 secondary 7812321
label +8087812321
ephone-dn  2
number 911 secondary 999
label 911+999
description EMERGENCY-911
ephone-dn  3
number 18005551234
label 18005551234
description 18005551234
ephone-dn  4
number 01161234567890
label 01161234567890
description 01161234567890
ephone-dn  5
number 7812321
label 7812321
description 7812321
ephone-dn  6
number 5005
label x5005
description OFFICE PHONE
ephone  1
mac-address 0008.A3FD.39FF
type 7960
button  1:1 2:2 3:3 4:4
button  5:5
banner motd ^C PSTN-IP-WAN ROUTER ^C
line con 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
login
transport input all
line vty 5 15
password cisco
login
transport input all
ntp server 192.168.1.1
end
PSTN_IP-WAN_RTR#
BR1_RTR#sh run
Current configuration : 1959 bytes
version 12.4
hostname BR1_RTR
boot-start-marker
boot-end-marker
enable secret 5 $1$XzHB$zFFng9eqiJDuCOuaXjiZk/
no aaa new-model
resource policy
no ip subnet-zero
ip cef
--More--
*Dec 10 05:10:49.038: OSPF: Send hello to 224.0.0.5 area 0 on Serial0/1/1.1 from 10.1.1.130
no ip domain lookup
interface Loopback0
ip address 2.2.2.2 255.255.255.255
no ip address
shutdown
duplex auto
speed auto
no ip address
shutdown
duplex auto
speed auto
interface Serial0/0/0
no ip address
shutdown
no ip address
shutdown
clock rate 2000000
description BR1-RTR_IP-WAN
no ip address
no fair-queue
clock rate 64000
ip address 10.1.1.130 255.255.255.128
frame-relay interface-dlci 201
interface Vlan1
no ip address
router ospf 1
network 2.2.2.2 0.0.0.0 area 0
network 192.168.20.0 0.0.0.255 area 0
network 192.168.21.0 0.0.0.255 area 0
network 192.168.22.0 0.0.0.255 area 0
ip classless
ip route 0.0.0.0 255.255.255.128 10.1.1.129
no ip http server
control-plane
line con 0
password cisco
logging synchronous
login
line aux 0
line vty 0 4
password cisco
login
line vty 5 15
password cisco
login
end
BR1_RTR#
Community Member
Please note, the default static route was an old entry - but regardless I don't have anything connected except for the subnets directly connected to BR1.  See below...
BR1_RTR#sh ip route
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
       D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
       N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
       E1 - OSPF external type 1, E2 - OSPF external type 2
       i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
       ia - IS-IS inter area, * - candidate default, U - per-user static route
       o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
     2.0.0.0/32 is subnetted, 1 subnets
C       2.2.2.2 is directly connected, Loopback0
     10.0.0.0/25 is subnetted, 1 subnets
C       10.1.1.128 is directly connected, Serial0/1/1.1
S    0.0.0.0/25 [1/0] via 10.1.1.129
BR1_RTR#
*Dec 10 05:35:49.038: OSPF: Send hello to 224.0.0.5 area 0 on Serial0/1/1.1 from 10.1.1.130
BR1_RTR#
Re: Point-to-Point Frame Relay OSPF question....please help. :-)
PSTN_IP-WAN_RTR:
shutdown
I guess you don't need further instructions ;-)
Rolf
Community Member
Thanks Rolf,
I'm an idiot.  :-(  **Egg on my face**  ....not the first time it's happened and it won't be the last.  That's why I love the world of Cisco, it makes you look stupid but you learn from your mistakes.  It's up and online now. :-)  Just a slight config change on the frame relay switch (PSTN_IP-WAN router) did it.
Thanks again buddy.
Eric
Eric,
you're welcome. Don't worry - we all have those moments of not seeing the wood for the trees ;-)
However, this gives a perfect example of the importance of troubleshooting methodology: Before you start tshoot upper-layer protocols, make sure that layer-2 is working. Sounds logical and simple but is often underestimated.
(I know: It's easy to be wise after the event.)
Good luck for your lab preperations!
Rolf
210
