point to point leased line connection.
Dear,
I have two location with 2901 router. now customer would like go for point to point leased line connection with the speed of 14mbps.From service provider side , they are going to provide RJ45 connector to terminate into the router. need suggestion to chose the HWIC card?? Can I use the below mentioned one?
HWIC-4SHDSL-E
Please suggest.
Hall of Fame Super Gold
Not enough information.
What protocol is the ISP supplying?  DSL?  MPLS?
The card you've chosen is for SHDSL.
It's DSL protocol. can you
It's DSL protocol. can you tell me the WIC part number
Still not enough information.
What kind of ADSL?  VDSL2, ADSL2/2+, Annex A, Annex B, Annex M, Annex L?
SHDSL Annex A, Annex B?
We can go on and on.  If you can't provide relevant information (instead of drip-feeding), you won't get the right response(s) in a timely manner.  Would it make a difference which one?  Yes, because the EWIC/HWIC cards are very expensive.  No one wants to give you the wrong part numbers.
hi,you could just use the
hi,
you could just use the onboard gigabit ethernet ports on the 2901.
124
