Community Member
Point to Point T1 routing issue
I have two problems in setting up a Point to Point T1 connection.
Here is how my network is setup
Router 14th
FastEthernet 0 - 192.168.5.158  is connected to our main office network
Serial 0 - 172.18.21.1 connected to T1 going to other location
All interfaces up
Router Shields
FastEthernet 0 - 192.168.6.1 is connected to the remote site local network
Serial0 - 172.18.21.2 connected to T1 going back to main office
All interfaces up.
Problem
I can ping from the remote location anywhere on the main office network.  But when going the other way I can ping the interfaces on the router  but not beyond. (i.e. 192.168.6.1 works , 192.168.6.2 doesn't).  Although I can ping from 192.168.6.2 anywhere going the other way. Also, 192.168.6.2 i can access a local website on a server at our main office, but I can't access the files on that same server from windows explorer.  the other issue is that the local web that I can access is extremely slow and it is a very basic page.
I have pasted the Configs from both routers below.  Any help would be appreciated.
14th#sho run
Building configuration...
Current configuration : 698 bytes
version 12.3
hostname 14th
enable secret 5 $1$9QKA$tGyITIePhWenx15CRMEzc1
enable password msi
memory-size iomem 25
ip subnet-zero
interface FastEthernet0
ip address 192.168.5.158 255.255.255.0
speed auto
interface Serial0
ip address 172.18.21.1 255.255.0.0
service-module t1 timeslots 1-24 speed 56
router rip
version 2
network 172.18.0.0
network 192.168.5.0
ip classless
no ip http server
snmp-server community public RO
snmp-server enable traps tty
line con 0
password msi
line aux 0
line vty 0 4
password msi
login
no scheduler allocate
end
Remote Router
Shields#sho run
Current configuration : 1264 bytes
version 12.4
hostname Shields
boot-start-marker
boot config flash:flash
boot-end-marker
enable secret 5 $1$VrlR$4uxBtsNCbzcJlDLCqhXJ/.
enable password msi
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip subnet-zero
ip cef
no ip dhcp use vrf connected
no ip ips deny-action ips-interface
interface FastEthernet0/0
ip address 192.168.6.1 255.255.255.0
ip rip advertise 20
duplex auto
speed auto
no cdp enable
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
no cdp enable
interface Serial0/1/0
ip address 172.18.21.2 255.255.0.0
fair-queue
service-module t1 clock source internal
router rip
version 2
network 172.18.0.0
network 192.168.6.0
ip classless
ip default-network 192.168.6.0
ip http server
no ip http secure-server
control-plane
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password msi
login
no process cpu extended
no process cpu autoprofile hog
end
1 REPLY
VIP Super Bronze
Re: Point to Point T1 routing issue
Couple of questions:
What is the purpose of
command if you are running RIP?
Why does the serial interface network has a class B mask?
usually serial interfaces are point-to-point with /30.
267
