12-21-2011 11:23 AM - edited 03-04-2019 02:42 PM
I am trying to use MLPPP to bond two T1's between a 1700 series and a 3600 series. I can't get the T1 to come up, I've tried HDLC and PPP independently and can only get the interface up and up when i put a hard loopback on either end, they will loopback to themselves. It seems like a config issue but I can't find it. Any help would be great.
1700 Series: Serial0:0
Current configuration : 2156 bytes
version 12.2
service timestamps debug uptime
service timestamps log uptime
hostname PARK_STREET
enable secret 5 <omitted>
ip subnet-zero
class-map match-all voice
match ip precedence 5
policy-map policy
class voice
class class-default
fair-queue
controller T1 0
framing esf
linecode b8zs
channel-group 0 timeslots 1-24
description ptp to financial center
controller T1 1
framing esf
clock source internal
linecode b8zs
description Park St to Etowah PtoP
bstun peer-name 172.16.2.1
bstun protocol-group 1 bsc
interface Loopback0
ip address 172.16.2.1 255.255.255.0
interface Multilink1
ip address 10.1.1.2 255.255.255.252
no cdp enable
ppp multilink
multilink-group 1
interface FastEthernet0
ip address 192.168.2.254 255.255.255.0
speed auto
service-policy output policy
interface Serial0
description Point-to Point to Financial Center
bandwidth 960
no fair-queue
interface Serial1
description Point-to Point to Etowah Bi-Lo
bandwidth 960
ip address 10.1.1.17 255.255.255.252
shutdown
no fair-queue
clockrate 125000
interface Serial0:0
no ip address
encapsulation ppp
ppp multilink
multilink-group 1
interface Serial1:0
bandwidth 1536
no fair-queue
router eigrp 100
network 10.0.0.0
network 172.16.0.0
network 192.168.1.0
network 192.168.2.0
network 192.168.5.0
network 192.168.6.0
network 192.168.11.0
network 192.168.12.0
network 192.168.13.0
network 192.168.14.0
network 192.168.20.0
network 192.168.30.0
network 192.168.50.0
no auto-summary
no eigrp log-neighbor-changes
ip classless
ip route 0.0.0.0 0.0.0.0 Serial0
ip route 0.0.0.0 0.0.0.0 Serial1:0 100
ip route 192.168.50.0 255.255.255.0 192.168.6.254
no ip http server
access-list 1 permit 192.168.2.1
access-list 1 permit 192.168.1.240
access-list 1 permit 192.168.1.190
snmp-server community <omitted>
snmp-server contact <omitted>
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password <omitted>
login
no scheduler allocate
end
3600 Series: interface Serial0:0
Building configuration...
Current configuration : 2485 bytes
version 12.2
service password-encryption
hostname CNB_3640
ip subnet-zero
no ip domain-lookup
call rsvp-sync
controller T1 0/0
framing esf
linecode b8zs
controller T1 0/1
framing esf
linecode b8zs
bstun peer-name 172.16.1.1
interface Loopback0
ip address 172.16.1.1 255.255.255.255
ip address 10.1.1.1 255.255.255.252
no cdp enable
ppp multilink
multilink-group 1
interface FastEthernet0/0
ip address 192.168.1.254 255.255.255.0
duplex auto
speed auto
interface Serial0/0:0
no ip address
encapsulation ppp
ppp multilink
multilink-group 1
interface Serial0/2
no ip address
no fair-queue
clockrate 125000
interface Serial0/3
no ip address
shutdown
clockrate 125000
interface Serial1/0
description Point-to-point T1 to Park Street
bandwidth 960
serial restart-delay 0
interface Serial1/1
description Point-to-point T1 to Athens Bi-Lo
bandwidth 1536
ip address 10.1.1.5 255.255.255.252
interface Serial1/2
description Point-to-point T1 to Vonore
bandwidth 1536
ip address 10.1.1.9 255.255.255.252
interface Serial1/3
description Point-to-point T1 to Kingston
bandwidth 1536
ip address 10.1.1.13 255.255.255.252
router eigrp 100
redistribute static
network 10.0.0.0
network 172.16.0.0
network 192.168.1.0
network 192.168.2.0
network 192.168.5.0
network 192.168.6.0
no auto-summary
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.252
ip route 0.0.0.0 0.0.0.0 10.1.1.2 200
no ip http server
ip pim bidir-enable
no logging trap
access-list 1 permit 192.168.1.12
access-list 1 permit 192.168.1.6
snmp-server enable traps tty
dial-peer cor custom
line con 0
exec-timeout 0 0
line aux 0
line vty 0 4
password 7 <omitted>
login
end
12-21-2011 12:22 PM
Lets talk about frist router -
2 controller on frist router T0 and T1 and you are also creating multilink-
Serial 0:0 and Serial 1:0 will be you interfaces.
just wondering why do you have same IP configured on two diffrent interfaces-
no cdp enable
ppp multilink
multilink-group 1
interface Serial0
bandwidth 960
no fair-queue
You should only configure S0:0 and S1:0 with encap ppp and make them part of multilink.
Before you create multiple check if the controller comes up or not - show controller will help to find out.
Ajay
12-22-2011 08:19 AM
The S1:0 interface is being used for something else. I had the address taken off of S0 but put it back after I gave up.
I can't get HDLC or PPP to establish on (1700)S0:0 to (3600)S0/0:0 even with no ip address set
Is there a difference between a vwic and wic other than the controller t1 commands assigning the channels and timeslots?
12-27-2011 01:21 PM
12-28-2011 12:51 AM
hi Aaron ,
The VWICs offer WAN interface card (WIC) and voice interface card (VIC) functionality in a variety of applications for enterprises and service providers who supply customer premises equipment.
The single- or dual-port T1 or E1 trunk interface in a VWIC:
•Supports voice, data, and integrated voice/data applications
•Supports structured T1, and both structured and unstructured E1 networks
•Can be used
–For voice/data services
–As a fractional n x 64 Kbps service for WANs (frame relay or leased line)
–For TDM drop and insert (voice/data integration) services
** Check the framing and line code with your service provider...
Remove multi link configuration and aasign ip address to serial interface and check the status of controller T1 and serial interface.Provide the output of controller and show interface serial
Wth rgds,
Satish
01-09-2012 06:04 AM
3600 router:
CNB_3640#sh controller t1
T1 0/0 is up.
Applique type is Channelized T1
Cablelength is long gain36 0db
No alarms detected.
alarm-trigger is not set
Version info Firmware: 20011015, FPGA: 11
Framing is ESF, Line Code is B8ZS, Clock Source is Internal.
Current port master clock: local osc on this network module
Data in current interval (234 seconds elapsed):
0 Line Code Violations, 0 Path Code Violations
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
Total Data (last 24 hours)
0 Line Code Violations, 3 Path Code Violations,
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 1 Degraded Mins,
1 Errored Secs, 1 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
T1 0/1 is down.
Transmitter is sending remote alarm.
Receiver has loss of signal.
Framing is ESF, Line Code is B8ZS, Clock Source is Line.
Data in current interval (238 seconds elapsed):
0 Slip Secs, 238 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 238 Unavail Secs
0 Line Code Violations, 0 Path Code Violations,
0 Slip Secs, 86400 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
0 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 86400 Unavail Secs
CNB_3640#
1700 router:
PARK_STREET#sh controller t1
T1 0 is up.
Description: ptp to financial center
No alarms detected.
Version info Firmware: 20011109, FPGA: 11
Data in current interval (437 seconds elapsed):
0 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
T1 1 is up.
Description: Park St to Etowah PtoP
No alarms detected.
Data in current interval (438 seconds elapsed):
17 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins
17 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
3144 Slip Secs, 0 Fr Loss Secs, 0 Line Err Secs, 0 Degraded Mins,
3144 Errored Secs, 0 Bursty Err Secs, 0 Severely Err Secs, 0 Unavail Secs
01-09-2012 08:26 AM
take a look at the clock source. If this is a telco supported circuit (i.e. not back to back) you should have clock soucre line
on all your interfaces. note the errored seconds on t1 1 for the park street router, and the frame loss on T 1 0/1 CNB_3640.
01-17-2012 07:18 AM
It is a point to point circuit with no clocking on the line.
The t1 1 is not even the circuit we are working with. That's not good.
01-17-2012 08:13 AM
Well, thats problem #1.
Set the clock source to line at both ends. Clear the counters and see if those low level errors clear up.
