07-30-2012 10:35 PM - edited 03-04-2019 05:07 PM
Hi guys,
First time here
i am having trouble with the point to point tunnel that i configured on the two routers
When i do sh ip int brief, tunnel on the both routers is whowing up but i am not able to ping the destination ip adddresses on the both router and lan ips
don't know where i am going wrong
interface Tunnel0
bandwidth 1000
ip address 10.2.0.1 255.255.255.252
ip virtual-reassembly
ip tcp adjust-mss 1460
tunnel source FastEthernet4.4090
tunnel destination 172.17.3.140
interface Tunnel0
description Tunnel to Auckland HO (CHEMAK1)
bandwidth 1000
ip address 10.2.0.2 255.255.255.252
tunnel source Dialer0
tunnel destination 172.23.2.206
chemak2m001#ping 172.17.2.206
Sending 5, 100-byte ICMP Echos to 172.17.2.206, timeout is 2 seconds:
Success rate is 0 percent (0/5)
CHEMAK1R001#ping 172.17.3.140
Sending 5, 100-byte ICMP Echos to 172.17.3.140, timeout is 2 seconds:
Please help
Atul
07-31-2012 12:13 AM
1- Add Keepalive command under the interface tunnel. keepalive 5 2 is ok. After timer expires it will show you if the tunnel is realy up o not.
2- Ping the tunnel destination with IP of tunnel source as source of the ping. It will show you that the path status.
07-31-2012 02:41 AM
hi Ali, thanks for the reply.
I did keepalive 5 2 and that made the tunnel protocol down.
still going throug the pain
07-31-2012 03:58 AM
Hi Atul,
Yiu can ping the tunnel ip address......(In ur case: 10.2.0.1 or 2), and you can not ping the provider ip address.
If you want to test the tunnel then try to ping tunnel ip address.
one more command to test tunnel:
test int tunnel 0
REgards
please rate if it helps.
07-31-2012 04:07 AM
Hi Sandeep,
Cant ping the tunnel ip address as well.
i used this command test int tunnel 0
chemak2m001# test int tu0
... Failed - not connected problem
1 interfaces: 0 passed, 1 failed, 0 skipped, 0 untestable
07-31-2012 04:45 AM
Can you paste the output of this coomand: sh int tunnel0 from both end.
Or just configure like this:
interface Tunnel1
desc bandwidth 1000
ip mtu 1300
ip tcp adjust-mss 1260
tunnel source xxx.xxx.xxx.xxx
tunnel destination xxx.xxx.xxx.xxx
means reduce the tcp adjust value .
If still not works then please paste the whole config of routers.(To get the whole overview)
Please rate if it helps.
07-31-2012 04:46 AM
Hi Sandeep,
As soon as i have removed the keep alive from the tunnel interface, tunnel come back up
and when i run this test int tu0 command, it give me the following result
CHEMAK1R001#test in tu0
!!!!!!!!!!!!!!!!!!!! Passed
1 interfaces: 1 passed, 0 failed, 0 skipped, 0 untestable
07-31-2012 04:50 AM
It means your tunnel is working.....
try to ping your tunnel ip address??
07-31-2012 05:12 AM
still can't ping the tunnel ip address 10.2.0.1 or 10.2.0.2.
even if the test command is showing me pass
07-31-2012 05:47 AM
can you paste the config of the interface ???
step1: just check with your provide(Is the ip address from provider is online.)
if still fails then please paste ur whole config.
