Policy Based Routing Based on Application
Does anyone have a config example that will allow PBR based on port number? I've got lots of examples using IP, but none with an extended ACL.
The situation is this, two ISP connections to a single router. Currently one line is backup. I would like one line used for DNS and HTTP requests, and the other to be used for everything else.
1 REPLY
Re: Policy Based Routing Based on Application
Define the ACL
access-list 101 permit tcp any eq 53
access-list 101 permit tcp any eq 80
route-map Policy permit 10
match ip add 101
set ip next-hop (or interface)
route-map Policy permit 20
int fa0/0
ip nat inside
ip policy route-map Policy
In addition to this your NAT config, needs to be updated with route-maps, so that you can NAT to the appropriate provider's ip address. More info about this can be found here.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080093fca.shtml
104
