Policy based routing on ports
I have a need to configure PBR on my network but I only want to use it for two ports, 80 and 443, the rest of the traffic should follow the normal routing rules. I have two networks the voice 10.10.x.x network and data 192.168.x.x network. I want all voice traffic to go accross the WAN while all data traffic goes through a VPN connection. All of this is working fine except when a PC wants to access a web page that is on the 10.10.1.x network. It goes accross the WAN from the remote branch because the routers know about the 10.10.1.x network but when the server on the 10.10.1.x network respons back it is being sent over the VPN connection because the routers do not know how to get to the 192.168.7.x network so it sends it to the firewall. I have configured PBR on the network now but I can only seem to get it to work when I specify the whole network range. I want to use PBR for port 80 and 443 only. Here is my working config and what I want to do.
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 10.10.1.250 255.255.255.0
ip policy route-map ccm-web
access-list 162 permit ip host 10.10.1.10 192.168.2.0 0.0.0.255
access-list 162 permit ip host 10.10.1.11 192.168.2.0 0.0.0.255
access-list 163 permit ip host 10.10.1.10 192.168.3.0 0.0.0.255
access-list 163 permit ip host 10.10.1.11 192.168.3.0 0.0.0.255
access-list 164 permit ip host 10.10.1.10 192.168.4.0 0.0.0.255
access-list 164 permit ip host 10.10.1.11 192.168.4.0 0.0.0.255
access-list 165 permit ip host 10.10.1.10 192.168.5.0 0.0.0.255
access-list 165 permit ip host 10.10.1.11 192.168.5.0 0.0.0.255
access-list 167 permit ip host 10.10.1.10 192.168.7.0 0.0.0.255
access-list 167 permit ip host 10.10.1.11 192.168.7.0 0.0.0.255
route-map ccm-web permit 12
match ip address 162
set ip next-hop 192.168.20.2
route-map ccm-web permit 13
match ip address 163
set ip next-hop 192.168.30.2
route-map ccm-web permit 14
match ip address 164
set ip next-hop 192.168.40.2
route-map ccm-web permit 15
match ip address 165
set ip next-hop 192.168.50.2
route-map ccm-web permit 17
match ip address 167
set ip next-hop 192.168.70.2
What I tried was:
access-list 161 permit tcp host 10.10.1.10 eq www 192.168.7.0 0.0.0.255 eq www
access-list 161 permit tcp host 10.10.1.10 eq 443 192.168.7.0 0.0.0.255 eq 443
and so on but it did not work for me. Is what I am trying to do possible? what am I doing incorectly?
  • WAN Routing and Switching
1 REPLY
Purple
Re: Policy based routing on ports
Try the following ACL instead of what you used initially:
Only the web-server will be using the www/443 ports. Your clients will be using a random port > 1023.
Hope that helps - pls rate the post if it does.
Paresh
114
