Community Member
policy based routing question!!!!*****!!!!!(*-*)
Hi all,
I configured this route-map my question is
if i add other next-hop in same statement like (f.f.f.f) how Mr.router-map will deal with it
route-map blabla permit 10
match ip address 110
set ip next-hop x.x.x.x f.f.f.f
X.X.X.X first IP
f.f.f.f second IP that i will configured it
1 ACCEPTED SOLUTION
Hall of Fame Super Blue
Re: policy based routing question!!!!*****!!!!!(*-*)
Yes you can do this. The router will used x.x.x.x as the next hop. If that is unavailable it will use f.f.f.f.
Jon
Jon
Community Member
I thought that will make load balancing between two IPs
102
