Policy based Routing with 871 Router
I want to implement policy based routing using my 871 route which has 1 Wan port and 4 Lan ports.is there any possibility through which i can connect more than 1 DSL connection on it and implemet policy based routing so whe 1 internet goes down the other becomes the primart i did tried adding 1 lan port in to different VLN but did received error that this version does not supports more than 2 VLANS
Hall of Fame Super Gold
Re: Policy based Routing with 871 Router
Please do "show version". If you image is not "advipservices", yes you need to upgrade. To do this, please contact your cisco reseller.
Here I have attached the file u have asked for
Bronze
You'll need to get a flash upgrade, then get the Adv. IP Services IOS so that you can do VLANs on your router.
You mean I have to upgrade to advance ip service i can even do that will this resolves my issue
Yes as it was mentioned twice you need to upgrade for the VLAN feature. The following document describes what is in the default image and what is not.
http://cisco.com/en/US/products/hw/routers/ps380/products_data_sheet0900aecd8028a976.html
As an appreciation to those providing answers, please rate useful posts using the scrollbox below!
188
