04-14-2009 07:22 AM - edited 03-04-2019 04:21 AM
I have 2 Internet connections over my 1841 router , 1 is terminated over the serial link and the other one over the ethernet link where as the 2nd ethernet port is for internal network. I want to implemet policy based routing so when ever some one tries to access any perticular IP he is routed through the 2nd internet connection also i want to know is there any way to shift the circuit automatically when the primary circuit ges down.
04-14-2009 07:41 AM
Imran,
First of all just define the traffic you want to send each link. Also add a backup link for them.
After that just do the following link to beat NAT problems.
Please check this link out.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080950834.shtml
HTH,
Toshi
04-14-2009 08:32 AM
Imran
If I am understanding your post correctly your primary Internet connection is the serial interface and the Ethernet connection is to be used as secondary/backup. If this is the case then a simple floating static default route using the Ethernet next hop should accomplish what you want.
Note that configuration of the Ethernet as a seconary/backup link is not necessarily related to what you configure for Policy Based Routing. The backup should operate independently from the PBR.
Rick
