policy based routing
I need to route to a destination (10.1.2.2) only when two interfaces are up(vlan 1 & vlan 2) and when any one of these interfaces are down packets must use a floating static route .is it possible?
Re: policy based routing
Hi Raj,
Yes thats possible. Under policy map give a condition as "Match Interface " and then set the route which you want.
So only when match condition will return TRUE value it will go to this route or elase will follow normal routing table.
Ankur
hi
please find the below config and letme know y it's not working.
Both these interfaces are connected to another switch and pining the directly connected interfaces.with static route the particular destination (10.1.1.2) is also pining. but policy based routing is not working y so?
interface Vlan500
ip address 10.17.17.1 255.255.255.0
ip policy route-map test
interface Vlan600
ip address 10.16.16.1 255.255.255.0
route-map test permit 10
match interface Vlan500 Vlan600
set ip next-hop 10.16.16.2
router#ping 10.1.1.2
Sending 5, 100-byte ICMP Echos to 10.1.1.2, timeout is 2 seconds:
Success rate is 0 percent (0/5)
router#
Hi rajiv,
Policy routing does not affect the packets originated by the router.
You need to add the following command in the global configuration mode to test it from the router
(config)#ip local policy route-map test
HTH, rate if it does
Narayan
108
