Community Member
Policy-map bandwidth allocation.
In the following configuraion of Policy-map what is the result of each class-map getting the bandwidth.
Policy map applied on T1 serial link (1540 kbps )
Policy-map WAN
class WEB
bandwidth percent 20
class SAP_Traffic
bandwidth percent 10
class class-default
fair-queue
As T1 configured bandwidth is 1540 kbps
CASE-1 :
20 % of T1 = 308 kbps for WEB class
10 % of T1 = 154 kbps for SAP_Traffic class.
And remaining will be used by default class.
Is my understand correct ?
OR
CASE-2 :
It is like this, after allocation of WEB bandwidth ( 308 kbps ) what remain is
1540 kbps - 308 kbps = 1232 kbps.
Now when allocating bandwidth for SAP_Traffic 10 % of the remaining will be allocated = 10 % of 1232 kbps = 123.2 kbps.
Which case is correct?
Please share the experience.
Any link on cisco.com
Thanks in advance.
Subodh
1 REPLY
Re: Policy-map bandwidth allocation.
Subodh,
It should be case 1. The bandwidth percent command is to reserve a percentage of the available bandwidth during congestion only. If the line isn't congested, then it would use up as much as it needed.
HTH,
John
HTH, John *** Please rate all useful posts ***
927
