07-16-2012 07:47 AM - edited 03-04-2019 04:58 PM
I'm trying to resolve an issue with phones on remote routers thet keep re-registering throughout the day. I changed the:
policy-map shaper
class class-default
shape average 2000000
service-policy voice_and_video
To:
policy-map shaper
class class-default
shape average 8000000
Not sure what I have just done but it didn't break it. The Comcast bandwidth is atleast 8000000 so, I figured I would match it with this.
What does this command effect?
Thanks, Pat.
07-17-2012 05:38 AM
John is it possible that the CIR could be less than 2mbs on a Business line? What am I losing by making my shaper less than the CIR? If the CIR is 4mbs up and I set my CIR to 2, I am limiting the router, correct? So if the line is 10 up and 3 down, what would be the right setting for the shaper?
sh processes cpu | i 5
PID Runtime(uS) Invoked uSecs 5Sec 1Min 5Min TTY Process
2 148000 59092 2 0.00% 0.00% 0.00% 0 Load Meter
4 341420000 44956 7594 0.00% 0.13% 0.11% 0 Check heaps
5 4000 15 266 0.00% 0.00% 0.00% 0 Pool Manager
10 178504000 4923 36259 0.00% 0.07% 0.05% 0 Licensing Auto U
14 128000 59059 2 0.00% 0.00% 0.00% 0 IPC Service NonC
15 44000 288521 0 0.00% 0.00% 0.00% 0 IPC Periodic Tim
16 32000 288521 0 0.00% 0.00% 0.00% 0 IPC Deferred Por
19 8000 59093 0 0.00% 0.00% 0.00% 0 IPC Loadometer
24 438248000 3137588 139 0.15% 0.17% 0.16% 0 ARP Input
25 204000 307739 0 0.00% 0.00% 0.00% 0 ARP Background
35 0 1 0 0.00% 0.00% 0.00% 0 RMI RM Notify Wa
37 32000 295457 0 0.00% 0.00% 0.00% 0 GraphIt
42 4984000 105003 47 0.00% 0.00% 0.00% 0 Net Background
45 256000 295277 0 0.00% 0.00% 0.00% 0 TTY Background
46 2816000 295468 9 0.00% 0.01% 0.00% 0 Per-Second Jobs
50 0 2 0 0.00% 0.00% 0.00% 0 AggMgr Process
51 452000 149102 3 0.00% 0.00% 0.00% 0 Fast Throttle Ti
52 0 1 0 0.00% 0.00% 0.00% 0 Token Daemon
53 0 2 0 0.00% 0.00% 0.00% 0 Transport Port A
54 3224000 61354 52 0.00% 0.00% 0.00% 0 HC Counter Timer
55 0 1 0 0.00% 0.00% 0.00% 0 dev_device_inser
56 0 1 0 0.00% 0.00% 0.00% 0 dev_device_remov
57 0 2 0 0.00% 0.00% 0.00% 0 AUX
58 0 2 0 0.00% 0.00% 0.00% 0 LED Timers
59 212000 4 53000 0.00% 0.00% 0.00% 0 ESWPPM
62 556000 2715 204 0.00% 0.00% 0.00% 0 i2c console redi
63 16000 295443 0 0.00% 0.00% 0.00% 0 Console redirect
65 3868000 105627 36 0.00% 0.00% 0.00% 0 OSPF-1 Hello
68 60000 295469 0 0.00% 0.00% 0.00% 0 Crypto Device Up
71 216000 436 495 0.00% 0.00% 0.00% 0 crypto engine pr
75 2364548000 488426 4841 1.27% 1.28% 1.27% 0 ILPM
82 36000 288512 0 0.00% 0.00% 0.00% 0 Ethernet Timer C
84 116000 295279 0 0.07% 0.00% 0.00% 0 PI MATM Aging Pr
85 0 16 0 0.00% 0.00% 0.00% 0 AAA Server
89 6992000 44727 156 0.00% 0.00% 0.00% 0 CDP Protocol
95 0 2 0 0.00% 0.00% 0.00% 0 IPAM/ODAP Events
96 864000 9215542 0 0.07% 0.07% 0.07% 0 IPAM Manager
98 4000 57 70 0.00% 0.00% 0.00% 0 IP ARP Adjacency
100 52900000 265318 199 0.23% 0.10% 0.02% 0 IP Input
101 0 57 0 0.00% 0.00% 0.00% 0 ICMP event handl
105 0 2 0 0.00% 0.00% 0.00% 0 PPP Bind
107 256000 9411 27 0.00% 0.00% 0.00% 0 CRYPTO IKMP IPC
111 208000 1154167 0 0.07% 0.01% 0.00% 0 SSS Feature Time
112 4888000 333058 14 0.07% 0.02% 0.00% 0 Spanning Tree
113 0 1 0 0.00% 0.00% 0.00% 0 X.25 Encaps Mana
115 0 1 0 0.00% 0.00% 0.00% 0 AC Switch
116 0 985 0 0.00% 0.00% 0.00% 0 Authentication P
121 164000 5734 28 0.00% 0.00% 0.00% 0 CEF background p
125 0 2 0 0.00% 0.00% 0.00% 0 L2X Switching Ev
130 4000 458 8 0.00% 0.00% 0.00% 0 TCP Timer
131 0 15 0 0.00% 0.00% 0.00% 0 TCP Protocols
133 4000 985 4 0.00% 0.00% 0.00% 0 HTTP CORE
135 36000 4931 7 0.00% 0.00% 0.00% 0 IP Background
137 188000 85 2211 0.00% 0.00% 0.00% 0 IP RIB Update
145 0 13 0 0.00% 0.00% 0.00% 0 Collection proce
150 0 1 0 0.00% 0.00% 0.00% 0 IP IRDP
151 0 1 0 0.00% 0.00% 0.00% 0 IPv6 Inspect Tim
152 0 1 0 0.00% 0.00% 0.00% 0 MQC Flow Event B
153 6424000 72783522 0 0.47% 0.48% 0.45% 0 HQF Shaper Backg
154 0 3 0 0.00% 0.00% 0.00% 0 RBSCP Background
155 4000 3 1333 0.00% 0.00% 0.00% 0 SCTP Main Proces
156 0 1 0 0.00% 0.00% 0.00% 0 VPDN call manage
157 0 1 0 0.00% 0.00% 0.00% 0 IPS Process
158 0 2 0 0.00% 0.00% 0.00% 0 IPS Auto Update
159 0 2 0 0.00% 0.00% 0.00% 0 SDEE Management
160 44000 577004 0 0.00% 0.00% 0.00% 0 Inspect process
163 36000 577004 0 0.00% 0.00% 0.00% 0 CCE DP URLF cach
165 0 2 0 0.00% 0.00% 0.00% 0 URL filter proc
171 0 1 0 0.00% 0.00% 0.00% 0 X.25 Background
175 0 1 0 0.00% 0.00% 0.00% 0 IDMGR CORE
178 36000 457 78 0.00% 0.00% 0.00% 0 LOCAL AAA
183 444000 2960 150 0.00% 0.00% 0.00% 0 Crypto Support
185 0 4 0 0.00% 0.00% 0.00% 0 Crypto CA
188 85644000 6211 13789 0.00% 0.11% 0.21% 0 crypto sw pk pro
191 15732000 35340 445 0.00% 0.00% 0.00% 0 Crypto IKMP
193 340000 15655 21 0.00% 0.00% 0.00% 0 IPSEC key engine
195 4000 34 117 0.00% 0.00% 0.00% 0 Crypto ACL
202 32000 180795 0 0.00% 0.00% 0.00% 0 PM Callback
205 4000 3 1333 0.00% 0.00% 0.00% 0 EEM ED Resource
207 36000 29529 1 0.00% 0.00% 0.00% 0 RMON Recycle Pro
215 4000 101 39 0.00% 0.00% 0.00% 0 EEM Server
225 0 2 0 0.00% 0.00% 0.00% 0 EEM ED SNMP Noti
234 8000 146 54 0.00% 0.00% 0.00% 0 Syslog
235 0 3 0 0.00% 0.00% 0.00% 0 EEM ED RPC
236 1540000 9230593 0 0.15% 0.12% 0.10% 0 PPP manager
237 920000 9230598 0 0.00% 0.06% 0.07% 0 PPP Events
238 12000 295450 0 0.00% 0.00% 0.00% 0 Multilink PPP
242 964000 59094 16 0.00% 0.00% 0.00% 0 Compute load avg
245 0 2 0 0.00% 0.00% 0.00% 0 Key Proc
250 56000 4923 11 0.00% 0.00% 0.00% 0 DFS flush period
251 0 167 0 0.00% 0.00% 0.00% 0 SSH Event handle
252 72000 428 168 0.00% 0.00% 0.00% 0 DHCPD Receive
253 2660000 2958941 0 0.07% 0.05% 0.04% 0 IGMP Input
254 3948000 6148381 0 0.15% 0.12% 0.09% 0 PIM Process
255 932000 2954526 0 0.00% 0.02% 0.01% 0 Mwheel Process
256 4000 4937 0 0.00% 0.00% 0.00% 0 MRIB Trans
257 0 4 0 0.00% 0.00% 0.00% 0 MFIB_cable
258 2388000 14742727 0 0.15% 0.15% 0.15% 0 MFIB_mrib_write
259 4000 10 400 0.00% 0.00% 0.00% 0 MFIB_mrib_read
261 1844000 38528 47 0.00% 0.00% 0.00% 0 NHRP
262 8000 85 94 0.00% 0.00% 0.00% 0 Tunnel Security
264 188000 295291 0 0.00% 0.00% 0.00% 0 DHCP Client
266 60000 577009 0 0.07% 0.00% 0.00% 0 IP NAT Ager
275 0 2 0 0.00% 0.00% 0.00% 0 SNMP Traps
07-17-2012 07:28 AM
Pat,
You'll need to spell out the word "five" for the show command to get the right output "sho proc cpu | inc five"
Probably not, but it's best if you find the actual rate.
You are limiting the router when shaping, but you're also somewhat protecting your traffic from being dropped at the PE router. Down speeds are generally higher than the up speed from most providers (I've never seen one the opposite direction, but I guess it could be possible). In your scenario, if you had 3Mb down/10Mb up, and you had a fastethernet connection of 100Mb, you'd want to shape your traffic to 10Mb (10000000).
07-17-2012 08:06 AM
No, it is 10 down and 3 up. I Screwed up. Knowing that, would I still want to shape 10000000?
So if it is 3 up, shouldn't I be shaping 3, as the shaping is done in the outgoing direction(Ithink) and that would be the upload direction correct?
sh proce cpu | i five
CPU utilization for five seconds: 8%/3%; one minute: 9%; five minutes: 8%
CPU utilization for five seconds: 9%/3%; one minute: 9%; five minutes: 8%
shproce cpu | i five
Thanks, Pat
07-17-2012 09:11 AM
CPU utilization looks fine. I would shape to 3Mb since that's the cir and you'll get the full amount that you're paying for. Can you post the actual policy from the router?
07-17-2012 10:16 AM
Here it is with 3000000:
policy-map voice_and_video
class call_setup
bandwidth 32
class internetwork_control
bandwidth 32
class voice
priority 128
class video
priority 460
class class-default
policy-map shaper
class class-default
shape average 3000000
policy-map mark_incoming_traffic
class discover_voip
set dscp ef
class discover_signaling
set dscp cs3
class discover_video
set dscp cs2
class non_voip
set dscp default
Thanks, Pat.
07-17-2012 11:05 AM
Pat,
One thing that I see is that your video is in the priority class along with your voice. This usually isn't recommended because there's only 1 LLQ. You can put multiple types of traffic in the queue, but in reality the video and voice will share the single LLQ. The problem with this is when someone is watching a video that's classified by this, the queue can get filled with video and then phones will fall behind in the queue and quite possibly be dropped or at least create latency. I would recommend taking your video out of the LLQ and create a bandwidth statement for it instead.
HTH,
John
