Policy-maps
I've noticed that there are default class maps being applied to interfaces on a Nexus 7010 line card and I'd like to know what the best practice way of removing it from this specific interface. At the moment the bandwidth on this link is being limited (config below).
I was planning to create a new class and policy map, but does the bandwidth need to be set to the speed of the interface within the policy-map, or will it default to that if I don't define the bandwidth specifically? This is a link to another office over MPLS and my main aim is to not have any qos being applied on this interface.
interface Ethernet10/46
  description ****
  speed 100
  duplex full
  udld enable
  ip address 10.3.x.x/30
  ip router eigrp 252
  no shutdown
#sh policy-map int eth10/46
Global statistics status :   enabled
Ethernet10/46
  Service-policy (queuing) input:   default-in-policy
    SNMP Policy Index:  301989889
    Class-map (queuing):   in-q1 (match-any)
      queue-limit percent 50
      bandwidth percent 80
      queue dropped pkts : 0
    Class-map (queuing):   in-q-default (match-any)
      bandwidth percent 20
  Service-policy (queuing) output:   default-out-policy
    SNMP Policy Index:  301991089
    Class-map (queuing):   out-pq1 (match-any)
      priority level 1
      queue-limit percent 16
    Class-map (queuing):   out-q2 (match-any)
      queue dropped pkts : 6970833
    Class-map (queuing):   out-q3 (match-any)
    Class-map (queuing):   out-q-default (match-any)
      queue-limit percent 82
      bandwidth remaining percent 25
      queue dropped pkts : 12584461
122
