Policy routing based on ports
briant
Can we set up a policy route to send web/ftp traffic to one interface, and all other traffic to a different interface?
We will also need to nat the web/ftp traffic.
Any help would be greatly appreciated.
Brian
Roberto Salazar
Level 8
Level 8
>> Yes, it's called Policy Based Routing.
Here is a link on cinfigurations guide:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fqos_c/fqcprt1/qcfpbr.htm
Please rate helpful posts.
PBR is used to make routing decisions based on policies set by the cisco router.
Here is the sample config :
hostname core_testing
interface Ethernet0/0
ip address 172.16.10.6 255.255.255.0
interface Ethernet0/1
ip address 172.16.64.6 255.255.255.0
ip route-cache policy
ip policy route-map policy_1
router eigrp 65001
network 172.16.0.0
no auto-summary
access-list 100 permit ip host 172.16.64.10 any
access-list 101 permit ip host 172.16.64.5 any
route-map policy_1 permit 100
match ip address 100
set ip next-hop 172.16.10.4
route-map policy_1 permit 200
match ip address 101
set ip next-hop 172.16.10.3
Regds
Saji k.s
Network consultant
Bangalore
I see how it is set up for source address routing, but what about destination port routing. All the documentation seems to talk about it address matching. Can we do destination port matching for policy based routing?
Brian
There may be a semantic issue involved in understanding this. The route map for Policy Based Routing may say match address 101 and it sounds like it is matching on addresses. But it is matching to an IP access list not just to addresses. So if you want to Policy Based Route for destination ports then just create the access list that permits the destination ports that you want to Policy Based Route. It really is pretty simple - and it works.
Rick
Rick
