Policy Routing for Router Generated Traffic
mwadam
This may be a little out of place since it is voice related, but the question is policy routing.
I need to be able to set the next hop for traffic being generated by the session target command on a voip dial-peer. This target of this peer is reachable via a SIP Trunk (point to point T1). Using static routes is not acceptable, as there are web sites that fall into the network statements and we only want voice traffic on this link. I have tested various route-maps by placing them on the loopback interface that H323 is bound to, the serial link that the router's default gateway (DS3) is on, as well as the data and voice gig interfaces. Regardless of the interface the route-map is on, I cannot control the next hop. Since this traffic is being generated by the router and not leaving an interface I am not sure where to apply the route-map. Maybe policy-routing is not the method I should be using.
Any ideas?
Thanks!!!
Adam
Richard Burts
Adam
It sounds to me like Policy Based Routing is what you are looking for. In general you assign the route map on the interface on which the traffic arrives (as you have stated). For traffic generated on the local router you use:
ip local policy route-map
Give it a try and let us know if that works.
Rick
Rick
9 Replies 9
Richard Burts
Adam
Rick
Rick
Rick,
Thanks for the reply.
This is what I have been doing. I applied the route-map to the loopback which is where H323 traffic should originate, but since CallManager passes the call to that interface and then the dial-peer is processing it, it is no longer passing thru that interface. This is why I tried other interfaces with no success.
Adam
The fact that traffic is not passing through the loopback interface is why I suggested that you try to use ip local policy. Traffic that is generated by the router is not processed through any interface and that is why ip local policy was introduced by Cisco.
Rick
Rick
Rick,
My fault, didn't pick up on the command difference. I apologize.
I will be giving this a try tomorrow and will let you know.
Thanks!!!
Adam
Rick,
I implemented the ip local policy and it worked perfectly! I appreciate all of your help!!!
Joseph W. Doherty
Perhaps?
(from 12.0 config guide)
Enable Local PBR
Packets that are generated by the router are not normally policy-routed. To enable local PBR for such packets, indicate which route map the router should use by using the following command in global configuration mode:
Command Purpose
ip local policy route-map map-tag
Identify the route map to use for local PBR.
All packets originating on the router will then be subject to local PBR.
Use the show ip local policy command to display the route map used for local PBR, if one exists.
This sounds more like what I am looking for. I will test it tomorrow and let you know the results.
Thanks again!
Adam
I am glad that the suggestion from Joseph and from me helped you resolve your problem. Thank you for using the rating system to indicate that your problem was resolved (and thanks for the rating). It makes the forum more useful when people can read about a problem and can know that they will read a successful solution to the problem.
I encourage you to continue your participation in the forum.
Rick
Rick
