policy routing
hi, i want to configure proxy interception feature on my network. There are about 10 vlans on my network and i want to configure policy routing so that the traffic for www should be intercepted and forwarded to the proxy server. For that i want to configure policy routing, is it possible to configure route-map and apply that route-map to interface VLAN. I have 3750 and 4948 switches.
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: policy routing
well you need three interfaces:
one towards the customer/client where you do PBR on incoming packets
one ouside WAN interface towards the internet
one dmz / horizontal link where you place the proxy / web cache
Incoming packets from users will be sent to the proxy ,the proxy will go to the internet opening a TCP session on behalf of the customer.
So you will have two coordinated TCP sessions
user <-----> proxy TCP_A
proxy <-----> real web server TCP_B
Return path will be
outside -> proxy -> || proxy --> user
TCP_B || TCP_A
Hope to help
Giuseppe
Re: policy routing
Hello Waseem,
if you can configure multiple VLan interfaces on them and you can have all of them up/up = they can do multilayer switching.
If so the answer is yes. Multilayer switches are able to implement PBR in a very efficient way by modifying the action to be done on the TCAM table. (the ip next hop I mean)
Hope to help
Giuseppe
Re: policy routing
hi giulsar
one thing which is confusing me is the placement of Proxy server, should i configure Layer3 port for the inside(LAN interface) and outside (WAN interface) network for the proxy server. Or should i place inside (LAN interface) network on some of the vlan and configure Layer 3 port for the outside (WAN interface). Then configure user on LAN having their default gatway ( ip address of interface VLAN) and apply route-map on interface VLAN to intercept the traffic for www.
Re: policy routing
Return path will be
TCP_B || TCP_A
Hope to help
Giuseppe
Re: policy routing
Hello
Thanks for your help.
Re: policy routing
Yes, Policy Routing works on these switches. You can configure route-map and apply it to interface VLAN.
But make sure that you should be having IPSERVICES image installed in the switch
Policy Routing doesn't works on BASE Image.
158
