Port Channel DWDM problem
I have 2 switches running 1GB dark fibre between sites (2 x 6748 switches) working. Currently one switch with SC SMF other with LC MMF
attempting to connect to new replacement 6748 with 720B sup to other site switch running new LC MMF (so both sides will be LC MMF), I'm unable get fibre connection working on standby sup.
port 5/1 is working but not port 6/1. I've swapped over fibre from working 5/1 to 6/1 (standby sup), 6/1 is able to see cdp neighbour and confirm connection 'show ether summ'.
Thought this would be a fibre problem as 5/1 fibre connection works on 6/1 when swapped. I inserted new fibre for Standby sup port directly into DWDM port, light when green on DWDM port, however still no link light on 6/1 or even 5/1 when I tried. Have looped fibre ends, still unable get connection for 2nd fibre.
I would think this would be a fibre problem, however after looping ends this would eliminate this. Would a config problem cause this no link light on the standby sup. see below configs.
NB: No alarms on DWDM
Only difference I can see is ?port-channel per-module load-balance? on new switch
new switch
port-channel load-balance src-dst-port
interface Port-channel100
description **link to
switchport
switchport access vlan 999
switchport trunk native vlan 999
switchport trunk allowed vlan 1-998,1000-4094
switchport mode trunk
switchport nonegotiate
no ip address
logging event bundle-status
logging event trunk-status
interface GigabitEthernet5/1
switchport
no ip address
channel-protocol lacp
channel-group 100 mode active
interface GigabitEthernet6/1
switchport
no ip address
other site switch
description **link to ukcap04-043-c65-ios**
switchport
no ip address
switchport
no ip address
switchport
no ip address
457
