Port forwarding
hi,
i have a pix acting as a vpn server behind adsl router of isp.i want vpn clients from outside can connect by vpn.for that portforwarding is required on adsl.Does anybody know which ports to be forwarded for vpn.vpn clent is 4.0.5 on windows.
thanks in advance.
rgrds,
Gold
Re: Port forwarding
On your ADSL router You need forward following:
protocol ESP (protocol number 50)
UDP port 500 (for ISKMP)
UDP port 4500 (for NAT traversal)
So router will be transparent for VPN connections
M.
Hope that helps rate if it does
Re: Port forwarding
thanks,
my adsl router only have tcp options
how can i forward ESP?
is there any oyher way to make adsl transparent???
Gold
Re: Port forwarding
command should be
"ip nat inside source static esp"
command was introduced in 12.2(1.4)
check this link for more info
http://www.cisco.com/en/US/products/ps6640/products_white_paper09186a00801af2b9.shtml
BUT
I didnt notice that its Easy VPN server (not site-to-site VPN)
It should be forward UDP 500 and UDP 4500 enough... You dont need forward esp for this scenario
M.
Re: Port forwarding
What you can also do, which may be the best solution is to force the DSL modem to be an actual modem, and have the pix do the pppoe. This way the pix will get the public address, and you won't have to worry about the problems that you're encountering with that modem in it's current state.
Jeff
Re: Port forwarding
i forwarded udp port 500 and 4500 but its not working.ANY HELP???
rgrds,
151
