Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Port open for pptp
Hi i'm using a cisco 857 router, my problem is when i connect to other network using windows pptp from our internal to outside i can't connect. It only reach up to verifying username and password then it will be cut off and it will give me error 619. A connection to the remote computer could not be established, so the port used for this connection was closed.
and 2nd problem is when i connect vpn from outside to our internal office. I can ping and remote everything but i can't access our wss site at my internet explorer that is using port 80.
Kindly check the attached config of my router
Thanks for your advise
Hall of Fame Super Silver
Re: Port open for pptp
Hello Marc,
see RFC2637
There are two parallel components of PPTP: 1) a Control Connection
between each PAC-PNS pair operating over TCP and 2) an IP tunnel
operating between the same PAC-PNS pair which is used to transport
GRE encapsulated PPP packets for user sessions between the pair.
Section 1.3
http://www.faqs.org/rfcs/rfc2637.html
So both must be allowed to have a successful PPTP vpn.
GRE uses 47 GRE General Routing Encapsulation [Li]
http://www.faqs.org/rfcs/rfc2784.html
http://www.iana.org/assignments/protocol-numbers/
You need to update the inspect rules accordingly.
Hope to help
Giuseppe
Hi Giuseppe thanks for the information. What command should i add and where should i put it?
444
