PortForward VPN Connection Through Cisco ASA HowTo
I have an OpenVPN running on a endian firewall which also acts as my main router.  I just placed an ASA5520 in front of the Endian Firewall and changed the IPs to match my new environment, so now if I want to access my VPN remotely I have to configure the ASA to port forward the traffic.  Endian firewall uses UDP 1194 for vpn connectivity.  My ASA so far as a basically default configuration on it.
To get my vpn connectivity I did this so far
static (inside,outside) udp interface 1194 "endian firewall outside IP" 1194 netmask 255.255.255.255         ##setup port forward
access-list INBOUND extended permit udp any any eq 1194        ##Allow UDP 1194 Traffic
At this point nothing seems to work.  I might have to troubleshoot my endian firewall but I was hoping someone could tell me if my logic is correct or if there is something I am missing as far as the cisco configuration goes?
Thanks for your time,
Joe
109
