Community Member
POS bandwidth
Simple question; When looking at the results of a "sho interface" on an GSR OC12 POS I see "bandwidth 622000Kbs" and "available bandwidth 598962 Kbs". What is the available bandwidth as opposed to bandwidth?
Additionally.....what is the rule of thumb as to when I would begin to see degradation far as a utilization percentage?
1 REPLY
Hall of Fame Super Bronze
Re: POS bandwidth
What's available is the # indicated under the available bandwidth :)
You can modify this # by using max-reserved-bandwidth command
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124cr/hqos_r/qos_m1h.htm#wp1113113
You will see degradation if your interface is running at 80% of more for long period of times.
944
