Power for Cisco 7609
I have 2x30amp 240 circuits pulled for a 7609. This should be more than sufficient?
Customer doesn't seem to agree.
Hall of Fame Super Gold
Re: Power for Cisco 7609
What PS and what line cards are installed on the router ?
That will let you determine the theoretical power usage.
Then, it should be confirmed with an clamp ammeter by a qualified electrician.
Please rate post if it does!
Gold
Your power needs to sized using the power plates on the power supplies in your switch. If it says x amps at 220 then that is what you should put in.
You can always put in more but you should never put in less. Many electrical codes require this also. Now the actual power it takes is related to the types of cards in the chassis and if the power supplies are both using power at the same time etc. So you could put in less and it fine at least until someone puts in a new board and trips off the breaker.
From the sounds of it the circuits you are going to put in are large enough since most the power supplies only want 16a max. The largest ones seem to just have more plugs rather than larger single plugs
111
