Webcast-Catalyst9k
PPP Authentication not working
I have configured two router R1 & R3 for ppp one way authentication. R3 calls into R1 for one way authentication however the serial interface does not seem to come up.
Can u help me with this. I have attached the config too with the debug outputs.
Thanks in advance.
Ryel
1 ACCEPTED SOLUTION
Re: PPP Authentication not working
Remove the line ppp authentication pap callin from the R3 Serial1/2 configuration and try again.
Best regards,
Peter
Best regards,
Peter
Thanks peter.
I have tested in my test lab and its working
R2#sh run int s1/1
Building configuration...
Current configuration : 188 bytes
interface Serial1/1
ip address 170.10.12.2 255.255.255.240
encapsulation ppp
serial restart-delay 0
no dce-terminal-timing-enable
ppp pap sent-username test password 0 test123
end
R2#
R1#sh run int s1/0
Current configuration : 141 bytes
interface Serial1/0
ip address 170.10.12.1 255.255.255.240
encapsulation ppp
end
R1#
Samy
Hall of Fame Super Gold
[edited]
Thank you Peter!!!
As always when working with PPP problems:
- Collect "debug ppp negotiation" and "debug ppp authentication" with "term mon".
Before asking others what could be wrong.
Note: do NOT use attachments for small files. Paste directly into text.
411
