ā10-05-2013 12:04 AM - edited ā03-04-2019 09:14 PM
Configured the ppp on cisco router 2800 by the serial interface + dial up external 56k modem connected by telephone company. What my question is that i need to allow only the phone calls from - specified number in router, because my client is connected through only Dial up modem+PC. block the unknown number
I found some solution about dialer commands. But I dont know how much this will help to solve.
Actually,
This is not a ISDN
This is not a Voice Network
I am not using any access server or any PBX.
""""""""""""""""""""""""" Give any Solution or IDEA """""""""""""""""""""""""""""
ā10-05-2013 09:02 AM
Router cannot know the calling number. If the external modem can receive CLID, then you have to cofnoigure there, otherwise it is not possible.
ā10-05-2013 09:52 AM
Yes I could receive the caller information in my phone..CLID facility having
Which is the command to restrict the calls, I hope this two
dialer caller XXXXX
dialer strin XXXXX
This is suitable for allowing for incoming / outgoing for the particular call.
If u know exact commands for allowing calls please share with US.
ā10-05-2013 10:11 AM
dialer caller XXXXX
dialer strin XXXXX
Answered above already: router does not know calling number and no command will help.
ā10-05-2013 10:26 AM
Please tell, what is the best solution for this issue.?
What should we do.?
ā10-05-2013 01:09 PM
Answered in my first reply, read it again.
ā10-06-2013 08:17 AM
I have the CLID facility, The "dialer command" which i shared this forum is correct.? If you know the exact command please do share your idea briefly, or clearly explain How to configure.
ā10-06-2013 09:24 AM
Again for the third time:
Consequently, router cannot block based on calling number
ā10-06-2013 11:07 AM
Maybe you can accept incomming call do authentication and callback to a predefined nummer?
After callback the Sissing is complete.
