PPP CHAP, PPPoATM, MLPPP
Hi all,
I am experiencing an inconsistent authentication issue with PPP CHAP on a 1721 with 2x WIC-1ADSL, PPPoATM and MLPPP. IOS is 12.4(7).
After a great deal of debugging etc. I am confident that the issue lies with the CHAP auth against my ISP. If the connection drops, I usually have to shut/no shut the dialer interface anywhere from 2 to 25 times before I get a CHAP SUCCESS message back; else the authentication just sits in a loop. *** SEE ATTACHMENT 'CHAP_1.txt' ***
This auth loop will go on indefinitely, and also occurs if the router has been power-cycled/reloaded- I will have to shut/no shut the dialer many times before I successfully auth and negotiate an IP- its a game of chance!
As you can see, there are never any CHAP FAILURE messages so auth is not being denied. After numerous shut/no shuts we finally get a SUCCESS back and things look good. *** SEE ATTACHMENT 'CHAP_2_SUCCESS.txt' ***
The router always talks to the correct ISP LNS, "g.dsl". I have spoken with my ISP who have no explanation; they see no failed auth's in their RADIUS logs.
Relivent portions of my conf are attached *** SEE ATTACHMENT 'running-config_1.txt' ***
Please can someone assist me with this? Please do not hesiate to request additional information.
Many thanks in advance.
Tom
Hall of Fame Super Gold
Re: PPP CHAP, PPPoATM, MLPPP
I'm afraid that your troubles can be due to attempting to MLPPP over two PPPoA interfaces.
Unfortunately that is not a common configuration and likely not tested / supported by cisco.
You can confirm that by shutdown one ATM and removing the minimum link requirement under dialer.
Understating what goes wrong would probably require a lot of debugs and ultimately is not said to be conclusive. If you can eliminate the mlppp, you can load share over the two interfaces and things should work nicely anyway.
Hi there,
Thank you for your prompt reply.
This is a MLPPP bonded service which is supported (and configured) by my ISP. When the two VC's eventually bond, throughput is exactly what would be expected given the line speeds in use.
I have condicted a lot of research through various Cisco tech documents and forums to try and establish a more correct configuration (Virtual-Templates, multilink interface?) however thus far I have been unsuccessful in defining a working configuration.
Can anyone shed some light on this plese?
Tom
153
