12-06-2006 04:50 AM - edited 03-03-2019 02:56 PM
I have two ADSL connections to one ISP both running on two different routers, can I configure PPP multilink on them for loadbalancing using one cisco router with 2 ADSL WIC card.
12-06-2006 10:17 AM
I have the same problem and I work around.
12-07-2006 12:17 PM
I guess this is a real tough call, because to enable the MPPP (or PPP Multilink) both the sides of the links needs to be MPPP aware.
So that both links would get a single IP.
Not only that, ADSL is not a direct L-2 protocol, its combination of 2 or 3 Protocols, e.g. it might be PPPoE or PPPoA or PPPoAoE, hence making it very heavy and complex.
Though this doesn't mean that thats the end of the world, but, effectively you may find ways to do some load sharing in order to effectively use both the Links.
Please rate if it helps.
Wilson Samuel
12-07-2006 12:19 PM
Hey, Wait a minute,
I guess this is possible, though I have never tried myself, but may be of some use to you:
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/32
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface ATM1
no ip address
pvc 8/32
interface Dialer0
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname xxxx
ppp chap password xxxx
ppp multilink
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer0
dialer-list 1 protocol ip permit
end
04-17-2007 02:58 PM
hey have any one tried samuel-wilson config??
please let me know how possible can this be!
thanks
