PPP Multilink using 2 different serials with different bandwidth
Hi everybody,
Sorry about this simple question but i didn't find information about.
I configured a PPP Multilink interface using 2 serial interfaces: one of them is at 960Kbps and the other one is at 2048Kbps.
In order to verify total capacity of multilink I'm using a tool to get link saturation, but i see total bandwidth is just at 1.8Mbps
Is this because of different capacities in serial links? how can i configure a propper ppp multilink in this case to get total bandwidth of 2.9Mbps?
Configuration is as follows:
ROUTER A:
interface Multilink1
description MULTILINK
ip address 192.168.101.13 255.255.255.252
ppp multilink
no ppp multilink fragmentation
multilink-group 1
interface Serial5/0/3
description S1
no ip address
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
interface Serial5/0/2
description S2
no ip address
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
ROUTER B:
ip address 192.168.101.14 255.255.255.252
ppp multilink
multilink-group 1
interface Serial0
description S1
no ip address
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
interface Serial1
description S2
no ip address
encapsulation ppp
no ip mroute-cache
no fair-queue
ppp multilink
multilink-group 1
1 ACCEPTED SOLUTION
Hall of Fame Super Silver
Re: PPP Multilink using 2 different serials with different bandw
Hello William,
my suggestion was to use Frame-relay encapsulation on faster link without multilink PPP involved
sorry if I haven't been clear.
R1
int ser0/0
clock rate 2000000
enc frame-relay
frame-rel intf-type dce
int ser0/0.30 point-to-point
frame-rel interface-dlci 30
bandwidth 960
ip address 192.168.1 255.255.255.252
int ser0/0.40 point-to-point
frame-rel interface-dlci 40
bandwidth 960
ip address 192.168.5 255.255.255.252
int ser0/1
enc ppp
ip address 192.168.9 255.255.255.252
bandwidth 960
clock rate 960000
on the other side equivalent commands without the clock commands and the frame-rel intf-dce
if this is possible you have your 3 equal costs paths links for example to use with OSPF.
Edit:
as probably noted by Paolo you have something that with normal CEF based switching should use only one of your possible paths.
You have a potential of multiple paths but if all the static routes are host based in reality one path will be used the one chosen by CEF based on ip source and ip destination.
Hope to help
Giuseppe
Hello William,
PPP multilink makes the hyphotesis that all member links are equal and has its own load balancing algorithm that uses member links in round robin.
In a case like yours:
you should have a chance to use FR on the 2048 link and to make two subinterfaces on it.
Then IP routing could be modified so that 3 1 Mbps links are seen as equal cost paths to destinations.
In other terms you need a way to logically divide the faster link in logical links that can run at a speed that is comparable with the slower link.
This can be done if you have a leased line that can be configured as a back to back FR setup.
one side has to act as FR DCE to make it working.
then on the FR link the 2.048 Mbps link you define two point-to-point subinterfaces and you can apply to them the command bandwidth 960.
each subif requires its own DLCI.
Hope to help
Giuseppe
Thank you very much for your suggestion Giuseppe!
I'm going to try it!
regards
Hi Giusepee, unfortunately multilink with Frame Relay didn't work.
However I solved the problem following the next advice:
The 2048K is around twice the other link about 960K. I stablished two HDLC links, and I used five different static routes using imaginary ip addresses for destination, then I routed three imaginary IP addresses trhough the 2048K link end two ip addresses through the 960K link.
using this I got to balance pakets between both unequal links sending more pakets for the bigger link than the other one.
configuration is as follows:
ROUTER A:
interface Serial1
description S2
bandwidth 2048
ip address 192.168.101.17 255.255.255.252
interface Serial2
description EDWIN SALAZAR GUALAQUIZA S1
bandwidth 2048
ip route 200.25.199.24 255.255.255.248 172.16.31.1
ip route 200.25.199.24 255.255.255.248 172.16.31.3
ip route 200.25.199.24 255.255.255.248 172.16.31.5
ip route 200.25.199.24 255.255.255.248 172.16.31.7
ip route 200.25.199.24 255.255.255.248 172.16.31.9
ip route 172.16.31.1 255.255.255.255 Serial2 192.168.101.14
ip route 172.16.31.3 255.255.255.255 Serial2 192.168.101.14
ip route 172.16.31.5 255.255.255.255 Serial1 192.168.101.18
ip route 172.16.31.7 255.255.255.255 Serial1 192.168.101.18
ip route 172.16.31.9 255.255.255.255 Serial1 192.168.101.18
ROUTER B:
interface Serial0
bandwidth 2048
no fair-queue
interface Serial1
bandwidth 2048
ip address 192.168.101.18 255.255.255.252
no fair-queue
ip route 0.0.0.0 0.0.0.0 172.16.31.2
ip route 0.0.0.0 0.0.0.0 172.16.31.4
ip route 0.0.0.0 0.0.0.0 172.16.31.6
ip route 0.0.0.0 0.0.0.0 172.16.31.8
ip route 0.0.0.0 0.0.0.0 172.16.31.10
ip route 172.16.31.2 255.255.255.255 Serial0 192.168.101.13
ip route 172.16.31.4 255.255.255.255 Serial0 192.168.101.13
ip route 172.16.31.6 255.255.255.255 Serial1 192.168.101.17
ip route 172.16.31.8 255.255.255.255 Serial1 192.168.101.17
ip route 172.16.31.10 255.255.255.255 Serial1 192.168.101.17
I hope this be useful for anybody.
Thank you
Hall of Fame Super Gold
Can you send some interface statistics showing that one interface is handling approx. twice the traffic than the other ?
some CEF show would also be interesting. Because I think CEF is smart enough to build only two equal weight adjacencies anyway.
Beside, EIGRP has the features of balancing proportionally to the bandwidth without using static or recursive routing.
Hello William,
R1
int ser0/0
clock rate 2000000
enc frame-relay
bandwidth 960
bandwidth 960
int ser0/1
enc ppp
bandwidth 960
clock rate 960000
Edit:
Hope to help
Giuseppe
sorry Giuseppe, i didn't understand your suggestion:
Here are Interface statistics por ROUTER A
Serial1 is up, line protocol is up
Hardware is cyBus Serial
Description: EDWIN SALAZAR GUALAQUIZA S2
Internet address is 192.168.101.17/30
MTU 1500 bytes, BW 2048 Kbit, DLY 20000 usec,
reliability 255/255, txload 113/255, rxload 18/255
Encapsulation HDLC, crc 16, loopback not set
Keepalive set (8 sec)
Restart-Delay is 0 secs
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 3d22h
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 94522
Queueing strategy: dual fifo
Output queue: high size/max/dropped 0/800/0
Output queue: 0/400 (size/max)
30 second input rate 145000 bits/sec, 111 packets/sec
30 second output rate 910000 bits/sec, 117 packets/sec
20446847 packets input, 3706549029 bytes, 0 no buffer
Received 0 broadcasts, 957 runts, 0 giants, 0 throttles
201362 input errors, 196545 CRC, 0 frame, 958 overrun, 2259 ignored, 3859 abort
26010944 packets output, 2850952244 bytes, 0 underruns
0 output errors, 0 collisions, 1 interface resets
0 output buffer failures, 11615358 output buffers swapped out
150 carrier transitions
RTS up, CTS up, DTR up, DCD up, DSR up
Serial2 is up, line protocol is up
Description: S1
Internet address is 192.168.101.13/30
reliability 255/255, txload 66/255, rxload 7/255
Keepalive set (10 sec)
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 257845
Queueing strategy: fifo
30 second input rate 64000 bits/sec, 54 packets/sec
30 second output rate 533000 bits/sec, 83 packets/sec
17326915 packets input, 3214788014 bytes, 0 no buffer
Received 0 broadcasts, 5 runts, 0 giants, 0 throttles
248897 input errors, 248849 CRC, 0 frame, 35 overrun, 0 ignored, 13 abort
21745431 packets output, 3038411926 bytes, 0 underruns
0 output errors, 0 collisions, 11 interface resets
8 carrier transitions
7500_CENTRUM#
It's not exactly but it's better for much what was happening. Multilink was saturating at just 1.8M
Thank you very much for your interest and suggestions
These interfaces have been statistically handling the same amount of traffic (less than 5% difference, and the interface that sent more packets, has sent less bytes anyway). That is not surprising, since you cannot fool CEF by virtue of few recursive static routes.
As mentioned above, if you want proportional traffic destination, either you run EIGRP with appropriate configuration, or statically decide which traffic to send on which link (more specific destination or PBR).
However, you have an excessively high percentage of input errors, indicator either faulty circuit or clocking problems. You should focus on that before traffic sharing.
632
