10-17-2005 09:42 PM - edited 03-03-2019 10:44 AM
I have a very simple configureation with PPP over FR, and runing RIP on it. there are two routes about this subnet in routing table like 150.1.1.1/32 and 150.1.1.0/24 both exist in routing table. can i fix this problem?
thanks
10-17-2005 10:41 PM
can you post the configuration of your PPPoFR router ?
GP
10-18-2005 12:39 AM
hi GP,
Currently, i dont have configuration, but it was simple, joging my memory a little bit.
A
int s0/0
frame-realy encapsulation
no frame-relay inver-arp
int virtual-template 1
ip address 150.1.1.1 255.255.255.0
ip rip triggerd
router rip
version 2
no auto-summary
network 150.1.0.0
B
int s0/0
ip address 150.1.1.2 255.255.255.0
ip rip triggerd
router rip
version 2
no auto-summary
network 150.1.0.0
thanks
10-18-2005 12:52 AM
this is just a guess, but possible, the virtual template interface is trying to install a peer route to the neighbor. Try and configure 'no peer neighbor-route' on the Virtual-Template, and see if that makes a difference...
GP
